Joule pre overhaul...
  • kharp1
    kharp1 Posts: 3,453
    Yep2 wrote: »
    kharp1 wrote: »
    Kentucky...let the jokes begin! :)
    I lived in Henderson for years...
    Across the Ohio from Evansville.
    Coldest temps Ive ever experienced -23°, 9ft snow drifts...
    And I have been to most of the BIG Western states Elk hunting!
    Unreal cold in KY!
    Pretty ugly himidity, too. Already had several hazardous air days this spring. Lovely Ohio Valley ozone. If you don't have sinus trouble when you move here you will in a couple of years.
  • kharp1
    kharp1 Posts: 3,453
    Clipdat Posts: 12,600
    Looks good! Got a special track/album in mind to play first through it?
  • dromunds
    dromunds Posts: 9,983
    How long is the break-in for those Jupiters, etc?
    tonyb Posts: 32,906
    edited June 2018
    It's been 30 minutes already Kerry, what goes man....how she sound brotha ? :)
    tonyb Posts: 32,906
    I'll volunteer to put on 150 hours. Be a huge sacrifice, but what the heck, I like Kerry. :p
  • marvda1
    marvda1 Posts: 4,873
    send it and I will break it in for you. you can pick it up when you pick up the ushers :p
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • kharp1
    kharp1 Posts: 3,453
    400 hours is what I was told to expect. BS I tell you!
    pitdogg2 Posts: 24,575
    kharp1 wrote: »
    You'll be on to something else by that time.....
  • kharp1
    kharp1 Posts: 3,453
    kharp1 wrote: »
    I've had this piece in the system for a while now, and, like it so much I decided to invest in it for the future. This one isn't going anywhere.
    tonyb Posts: 32,906
    edited June 2018
    kharp1 wrote: »
    kharp1 wrote: »
    Atta boy Kerry, once you get a piece that tickles your fancy, hard to let go of 'em. You spent years looking, flipping gear in and out. Sometimes we realize too late we should have kept xyz piece. If your Joule is now playing anywhere near the LA-300 levels, I'd keep that baby too, give it a back rub, send it flowers on it's anniversary. ;)
    In my personal observations, once you get to a certain level in audio, the amount of coin you have to spend increases greatly to achieve smaller jumps in sound quality.
  • maxward
    maxward Posts: 1,516
    It looks great! What are your impressions so far?
  • kharp1
    kharp1 Posts: 3,453
    Still tight. Hasn't opened up yet.
  • kharp1
    kharp1 Posts: 3,453
    edited June 2018
    Ok, I'm noticing a few things early on. One concerns me and am in dialogue with Rich about it, and that's the gain is lower than before. Even changing the jumper didn't help much. I am turning it up to the 3 o'clock position where before about 12-1 was where it pushed the best. I've switched the 5751 for a 12ax7 and it's better, however, when I tried a 12ax7 previously I couldn't use it due to too much gain, to the point of distorting. This concerns me a bit.
    The bass doesn't quite have the slam it did before, but, I expect that to change and I'm not concerned too much with that. What I do have is incredible bass detail!!! Far more palpable bass detail than before, and, I expect that will probably only get better with more break in.
    Stage isn't as wide as before, but, I think that will change as it breaks in. It's already changed some. Has very good stage depth, but, it had pretty good depth before. Again, I think these will only improve over the next few weeks.
    Interesting. I wonder what caused the gain structure to change.
  • kharp1
    kharp1 Posts: 3,453
    I'll let you know. There were a couple resistors added that may be causing it, but, if I'm understanding correctly I doubt that's it. This from Rich:
    The only thing I can think of is that I changed the output loading resistance..
    which is a pretty high value. I did lower its value, but as I said its still pretty
    high (this is there to provide some load on the output of the preamp during
    warm-up before the mute releases and provide a drain path for any DC charge
    that gathers on the output coupling cap). Maybe with your amp, the value is
    affecting the gain due to the loading combined with the input impedance of
    your amp. This is the only thing I can think off that may affect the gain.
    The capacitors can’t change the gain, the only serve a coupling function. The 6350 and
    5751 tested fine. The line stag biased to spec well too (not that has any impact on the gain
    as that is fixed by other factors in the circuit).
    If you look at the wiring inside the amp right on/at the RCA outputs, you will
    see a small resistor soldered there (one for each channel) across the output. If you feel up to it
    and can get to (reach) the lower one – you can cut them out (you only need to
    cut one lead on each) – this will leave the factory loading resistor on the circuit
    board in place (which is 500K ohm).
    heiney9 Posts: 25,080
    Everything you mentioned w/exception of the gain structure will change, pretty dramatically after a long break in. This is the most frustrating time, waiting for the parts to open up. I know you know that, just giving reassurances.
    tonyb Posts: 32,906
    edited June 2018
    Give it time....I'd leave it playing 24/7. Worst case scenario, you snap those 2 resistors. Tell us how the sound progresses after a week.
    Did ya ever get those JWM speakers fixed ? Or do ya want to trade for some Bose speakers and ERA D5's ? :p:p
    tonyb Posts: 32,906
    Anything working in your favor now that you've got a few hours on it ?
  • kharp1
    kharp1 Posts: 3,453
    Yes and no. I'm having to use an 12ax7 do get the gain I like, but, that puts mids a bit forward and slightly hot. Not something I couldn't live with if forced to, but, it what I want. My left volume motor has developed an issue. It's going back for a volume motor upgrade and maybe some further adjustments, but, not yet. I'm going to put some more break in time on it before sending it back.
    I can't say enough good about Rich Brkich at Signature Sound! He's been great at talking with me about thoughts and plans in trying to get this to where it needs to be.
    F1nut Posts: 49,799
    The volume pot motors in the Joule's tend to strip a gear. I replaced one for brgman in his.
  • kharp1
    kharp1 Posts: 3,453
    It gets to a certain point and stops moving and I see no physical binding. Thanks Jesse.
    F1nut Posts: 49,799
    There's a worm gear on the motor shaft that drives the gear which in turn drives the knob shaft. One or both are damaged. These are inside a small metal box attached to the motor.
    F1nut Posts: 49,799
    This is your pre, see the metal box between the motor and face? Inside are the gears.
    F1nut Posts: 49,799
    kharp1 wrote: »
    Can you turn it all the way by hand?
  • kharp1
    kharp1 Posts: 3,453
    F1nut Posts: 49,799
    In that case, I'm 99% sure you have a stripped/broken gear.
  • kharp1
    kharp1 Posts: 3,453
    I switched the Valvo Hamburg 12ax7 back to the Raytheon 5751 yesterday, and, today when I fired up the tunes it was like flipping a switch with the gain. I'm hearing gain like I would expect. The sound is starting to open up and I'm really liking what I'm hearing.
    tonyb Posts: 32,906
    I've read about many owners trying the 12ax7's, nobody really liked them all that much. Judd himself said that they have tried every compatible nos tube in his circuit, and the ones that came with the Joule's and that he recommends, are the best to his ears.
