Problem with Yamaha RX-A2070
MilitoMilito Posts: 67
I just got my 2070 from accessories for less today and the unit looks great except for one problem. The 5th foot (one in the center) is higher than the rest and it high centers on it.
Anyone else had this kind of problem with the upper RX-A Receivers?
I can't hook it up right now to see if there are any others issues as I'm waiting for our wood floors to be put in. I'm going to call accessories for less to see what can be done about it tomorrow.
  • ZLTFULZLTFUL Posts: 4,533
    Since it is most likely a factory refurbished piece, see if the center foot was "bottomed" out or tightened all the way down. Sometimes, in a rush to get product out the door, they simply overlook little things like that.
  • MilitoMilito Posts: 67
    Thanks for the reply, that was one of the first things I checked. I even took it off to see if it was seated correctly and also checked all of the feet.
  • ken brydsonken brydson Posts: 7,011
    edited June 14
    You could add washers to the corner feet to level it out. Just a thought...
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
    I called accessories for less and they told me to call Yamaha. I put some add on rubber pads on it last night to even it out so I'll probably just do that even though I'm a little upset the center foot is so far off compared to the other feet.
  • jeremymarcinkojeremymarcinko Posts: 3,039
    So weird. Does the corner feet have the felt pads under them? I’m pretty sure mine does at the corners.
    Yes
Howdy, Stranger!
