Rated vs. Actual Power & Volume Control
So, I’ve got a question concerning power.
Let’s say an amplifier is rated to 300w RMS (20-20000hz). Now let’s say my speaker is only rated to 250w. Volume control goes from -80 dB to +16.5 dB. At what volume level would it actually be safe to use this amp/speaker combo?
I’m figuring as long as I don’t turn it above, say -20 or so? Any input would be welcomed.
  • ZLTFULZLTFUL Posts: 4,615
    edited June 13
    Ignore wattage ratings for speakers.
    Frankly, it is misleading.
    I have a pair of speakers rated at 100 watts running on a 200wpc amp.
    And they will drive you out of the room with volume before the amp is even close to clipping.
    Clipped signals is what kills speakers...power will too but it is 90% clipping vs 10% overpowering speakers. *note 78% of all statistics are made up on the spot*
    Then there is pre amp and amp gain (or lack thereof), distortion levels, tiny little spider like gremlins that eat small children...
  • NightfallNightfall Posts: 7,545
    60% of the time it works every time.
    afterburnt wrote: »
  • BlueFoxBlueFox Posts: 10,140
    Use your ears. When it sounds bad, turn it down. If you feel technical then buy a Sound Pressure Level meter so that you can put a number on what you hear. Of course, this assumes you have ‘normal’ speakers that will let you know they are hurting. :)
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
  • alucidideaalucididea Posts: 103
    ZLTFUL wrote: »
    My thoughts exactly.
    BlueFox wrote: »
    I agree with that. I guess I’m trying to create a general rule of thumb for myself.
    The problem, to me, is that volume controls have different meanings in different setups. A number in one setup doesn’t necessarily relate to another setup.
    Lumin S1
    Sony XA-5400ES SACD
    BlueFox wrote: »
    Fair enough.
  • mpitogompitogo Posts: 281
    alucididea wrote: »
    I would ignore the power (unless it’s clipping). The volume control suggests your preamp is able to calibrate to reference levels. At common THX levels -20db on the volume knob should produce around 85db from the speakers. This is a normal listening level and doubt you would be overdriving and pushing more than a few watts. If you know what your speakers maximum output db is it would be relatively easy to derive the max volume level and compute the power.
    Music-2.0 Raidho D-3.1 | Audio Research Ref 40 | Jeff Roland 925 | Esoteric Grandioso K1 | Transparent Reference, IC, Speaker and Power | HRS SXR Rack
Howdy, Stranger!
