Can you leave your ipad plugged in?
afterburntafterburnt Posts: 4,425
This Lightning server doesn't lock up as much if I leave it on. Can you just leave it plugged in without hurting it?
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • txcoastal1txcoastal1 Posts: 9,775
    afterburnt wrote: »
    Oh hellNO it will melt
  • afterburntafterburnt Posts: 4,425
    And burst into flames?
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    iPad batteries last a long time
    I don't like keeping any of my portable topped off so to speak. You can probably use a couple days then plug in over night and so on
  • msgmsg Posts: 4,196
    edited May 13
    Bruce, is it the app that locks up when your iPad's display goes to sleep? This is for your Auralic Mini, yes?
    iPads have pretty good battery life, don't they? Maybe you can set your display to stay on all the time, and just dim it as needed with the quick-access control during your listening sessions.
    But yes, what Ron said - it'll melt.
    And burst into flames.
    I've seen it a million times.
    While playing tunes set iPad to stay auto lock off
    Yes you can leave plugged in while doing so
    @msg Scott, correct. I do have the display turned down but I don't see the sleep settings.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • rpf65rpf65 Posts: 1,718
    Sleep settings, maybe do not disturb.
    Your auto-lock function is under display and brightness.
  • DSkipDSkip Posts: 14,667
    Low light and keeping it awake is the most important thing. Due to the iOS settings AURALiC can't keep connection with the server unless the lightning app is the active app. Repeatedly changing apps will cause it to freeze as it reconnects.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • BlueFoxBlueFox Posts: 10,053
    I keep both my iPads plugged in all the time. Same with my iPhone when at home.
    Bud - Silicon Valley
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    rpf65 wrote: »
    Yes, this. I have an old iPhone I use for when I go riding, and if I want to sync Spotify for offline, I have to disable auto lock until it's synced, or else it stops syncing when the display sleeps. Sounds like what's happening to your Lightning app, Skip confirms.
  • mlistens03mlistens03 Posts: 1,405
    edited May 14
    I keep my iPad mini plugged in to full charge, then I unplug it and use it down to around 30-40% or so (usually 2-3 days) and then go and set it on my desk and plug it in til it’s charged.
    I don’t think it’s good for a battery to be charged to a high capacity for extended periods of time, or to be fully dead for extended periods of time. It’s recommended by Apple, Lenovo, drone manufacturers, anyone who makes batteries, etc. to store your device fully shut down at around 60% battery. If you are coming back in a few days, then don’t worry about it, but if it’s more than a week, I discharge it down to around 60% and shut it down.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
  • steveinazsteveinaz Posts: 18,265
    I wouldn't, Ipad power supplies get really HOT.
    Transport: Oppo BDP-103/USB HDD | Preamp/DAC: Benchmark DAC2L | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable XLR; Kimber 8VS Bi-Wire; Belden 1694A Dig Coax | AC Power: Panamax M5300-PM
    Mine don't. I have a regular iPad Retina, and an iPad mini-Retina, and neither get hot even though they are plugged in 24/7.
    Lumin S1
    Sony XA-5400ES SACD
  • rooftop59rooftop59 Posts: 4,307
    BlueFox wrote: »
    The charging block plugged into the wall doesn't get hot? I think that's what he means. My iPad doesn't get hot but the charging block could fry an egg...
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
    rooftop59 wrote: »
    BlueFox wrote: »
    Some of our charging blocks get warm, and others don’t. None of them get hot enough to be worried about, IMO.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    rooftop59 wrote: »
    BlueFox wrote: »
    No. Just checked. They are room temperature.
    Lumin S1
    Sony XA-5400ES SACD
    I'm talking about the charger. What's odd is my wifes Ipad mini 3 PS gets hotter than my Ipad mini 4, but even my 4 PS gets pretty darn warm.
Howdy, Stranger!
