SDA SRS 2 + GFA 555 = WOW!!
JayMXJayMX Posts: 101
Finally found a bigger amp at a reasonable price for the SDA's. Holy ****!! That is all... :o :o :) :)
Upstairs 5.1.2:
Marantz NR1607
L/R - Modified Monitor 7C (194’s, Dynamat, Sonicaps, Mills, H-nuts)
Center - Yamaha NS-C310
Surrounds/height/Atmos - (4x) Proficient in-ceiling
Sub - RBH TS10AN
Marantz DV7600
Downstairs 5.1.4:
Marantz SR6011
Adcom GFA 555 feeding L/R
L/R - SDA SRS 2, RTA12C (194's)
Center - RBH 700-CX
Surrounds - Monitor 5b (SL1000)
Height/Atmos - (4x) Polk RC60i
Sub - JBL 12” frankenspeaker
Samsung bluray
Office:
Cambridge Soundworks Amp
Monitor 4b (Peerless)
Spares:
Monitor 10a, Monitor 7b (Peerless), Monitor 5c
...and more to come, it’s a sickness.
  • FestYboyFestYboy Posts: 2,521
    Amazing what a little current will do... ;)
  • JayMXJayMX Posts: 101
    I’m considering it a Father’s Day present to myself! :D
    Upstairs 5.1.2:
    Marantz NR1607
    Sub - RBH TS10AN
    Marantz DV7600
    Downstairs 5.1.4:
    Marantz SR6011
    Center - RBH 700-CX
    Samsung bluray
    Office:
    Spares:
    I always thought the soundstage was impressive before, but it’s just amazing now. Channel separation is very impressive! Dead silent when it’s idling. Also, even at low levels there is a “meatyness” that I never experienced before. I am really amazed by this old gal! Love it!
    Upstairs 5.1.2:
    Marantz NR1607
    Sub - RBH TS10AN
    Marantz DV7600
    Downstairs 5.1.4:
    Marantz SR6011
    Center - RBH 700-CX
    Samsung bluray
    Office:
    Spares:
  • Tony MTony M Posts: 5,574
    So you got a Clean Adcom GFA-555 original Nelson Pass AMP? :o B)
  • txcoastal1txcoastal1 Posts: 9,774
    Tony M wrote: »
    :) John Curl
  • motorstereomotorstereo Posts: 799
    txcoastal1 wrote: »
    Tony M wrote: »
    :) John Curl
    You sure about that?
    Old 16th August 2002, 11:06 PM #2
    Nelson Pass is offline Nelson Pass United States
    The one and only
    Adcom 555II - Nelson Pass ?
    I designed the 555. I believe the Mk II added a couple
    of what were considered improvements, and it seemed
    to me that it included triple darlington outputs instead
    of 2 follower. I might have the schematic around, but
    all told it was a simple bipolar design with a current
    sourced input diff pair followed by a common-emitter
    gain device that was also current sourced. This drove
    the followers.
    It was typical of all the 5XXX amps that I did the first one
    and then they improved it until it had too many parts,
    and then I would design the next in the series
    Americo Borza sent me an old 555 in the hopes that I
    would update it, and it still sits here, a perfect candidate
    since so many of them were built.
    Personally, I would score a few of these and run them till
    they die and then update them. If you wait long enough,
    an update will be issued.
  • ZLTFULZLTFUL Posts: 4,524
    John Curl worked with Parasound while Nelson Pass worked with Adcom.
    It amazes me that there are so many amp designs still being made.
    Why don't people just copy Nelson Pass's designs or other great designs of the past and present to get maximum performance? Is there copyright laws in effect for 30 years?
  • DSkipDSkip Posts: 14,666
    edited June 12
    Usher does that. They made some minor changes that Pass was on board with.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
Howdy, Stranger!
