I was thinking...
1246
  • HermitismHermitism Posts: 1,658
    msg wrote: »
    I like your spirit, Micah. You seem like a good kid. Enthusiastic, polite, curious.
    I would also like the originals of your stand drawings to put on my fridge if you're not putting them up on your own. I can send you another box of crayons (Crayola 64 w/built-in sharpener on back) or colored pencils.
    I'd like to "Agree" part 1 and "LOL" part 2, but can't.
    I'll select "Like", it's in the middle of the two.
    2.0 - Marantz NA8005 | Polk LSiM703 | PS Audio: Duet, Power Port Classic, PerfectWave AC5 x2 PC | Wireworld Equinox 7 IC | Sanus UF30 | OC703 Panels
    6.1 - Pio Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | Monster HTS 5000 | DCF124BW x3 SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate x2 HDMI | M850SW | PS Audio Power Port Classic x2 | OC703 Panels
  • mlistens03mlistens03 Posts: 1,016
    msg wrote: »
    Thanks!
    Ha! I prefer pens. I don’t draw much either, just speaker designs and the like on occasion. When I do, I’m told I’m really good, but I don’t enjoy it much, so why would I draw if I don’t enjoy it?
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • tonybtonyb Posts: 29,061
    mlistens03 wrote: »
    msg wrote: »
    Thanks!
    Because it's the only way to get those thoughts bouncing around in your head out. Many smart people actually hated to draw, but was the only way to get others to visualize their thoughts. Keep at it, your doing just fine.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    I was at my friends house late last night, and we listened to them for a long time. They are awesome! They have a nice soundstage, and sound flat but at the same time they are lively and enjoyable. Off axis they sound decent, but once you get in the sweet spot they do something amazing. Overall, awesome speakers, and I want them. :grin: :wink:
    tonyb wrote: »
    mlistens03 wrote: »
    msg wrote: »
    Thanks!
    Ok, I’ll continue to draw and design things. I generally keep all my designs in my head, but I’ll try to draw them out.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • Tony MTony M Posts: 5,364
    edited May 24
    I like the fact that Micah is using GRAPH paper!
    I should take pictures of some of my old projects that were designed on graph paper first. 1 square equaled something so I could look at symetry, balance and useage of materials and lengths I would need.
    I took Mechanical drawing/Drafting in high school and loved it. Blueprint designing of homes was the first year. I moved after that but learned a ton. The Teacher was pretty good but a little too strict. But I understood his passion. He was a perfectionist too.
    I smiled when I saw the graph paper but.... didn't like how the squares weren't used to scale.
    PS. I once had to draw a deck design we were going to use to replace an old one to the City Council in some town in Virginia. We got approved to do it and the Council said it was the best proposal drawing they had ever received. I included grass and bushes and good detail to SCALE. They loved it.
    Oh, just like yours Micah, I had FRONT and TOP views on one page also. I also liked how you provided your top view imaginary view for us to see. You should take up Drafting!! You have the imagination and skills to put thoughts down on paper in 3-D.
    You're in a league of humans with that talent that is small. Try looking into that trade. It pays OK too. You won't have to work in bad weather either.
  • txcoastal1txcoastal1 Posts: 9,603
    For a easy paintable, industrial, sturdy configuration
    3-pieces of 1" gas pipe and 6-floor flanges
    Add a top and a base
    I know he was thinking about PVC or Aluminum but you'd have to screw through the pipes from the inside.
    I don't think they make flanges for Aluminum or PVC pipes, do they?
    edited May 24
    Tony M wrote: »
    I am a bit of a perfectionist myself, so I get that. Lol
    the paper was quite small, I usually use them for scale, but there wasn’t enough room.
    I feel like front and top views are essential to a good design, it is impossible to actually see the design without it.
    txcoastal1 wrote: »
    I was thinking about the same except I wanted to use bigger pipes, I don’t want to take the risk of it breaking with an expensive pair of speakers.
    Tony M wrote: »
    I don’t know if they do or not. My plan was to cut holes in the wood (one of the holes at an angle) and screw the pipes into the wood. Then I would fill it with sand and find some way to cover the holes.
    I am seriously considering the Signatures, although I think the LSiMs would work better in the long term. I plan to use these speakers for years and years, and I think the next place I will live will most likely be an apartment when I move out. I feel like the S60s or really any of the Signature towers would be too big and I would just end up annoying the neighbors. What do the rest of you guys think?
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    I have officially decided I’m going with the 703s, unless one of you guys talk me out of it. :wink:
    I’m also gonna wait on building stands until I have the money for the 703s. That way, if something happens, I won’t have a pair of stands and no speakers.
    Thanks again for your help,
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    There's nothing but PRAISE for those 703"s. GREAT CHOICE! ;) B)
    What color do you have in mind?
    Tony M wrote: »
    I am leaning towards the midnight mahogany, but really whatever is available. I think the mahogany will look stellar in my room, the dark finish next to my desk. I’m really looking forward to seeing the wood grain in the mornings when the sun shines in through the windows. And, they will sound a few thousand times better than they look! :smiley:
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    I don't know...
    I think they'll look as good as they sound! ;) :p B)
  • halohalo Posts: 4,016
    edited May 26
    mlistens03 wrote: »
    Micah
    @mlistens03 Keep an eye out for "Scratch & Dent" prices on the Signature Series, especially the S60's. When Polk offers an additional $100 off, you get that $100 off the already low price on "Scratch & Dent" speakers! I purchased my set from Crutchfield (you can get the brown walnut or the black walnut from them). With the floorstanding speaker design, you don't need to build the stands and floorstanding speakers are actually easier to drive than bookshelf speakers. Again, the downward firing power port really makes placement versatile and easy compared to rear ported in your small room. To me, the Signature Series is a no-brainer here. That'll also free up some room $ if you decide to drive them with some high(er) end electronics. Win/Win. Also, you are far less likely to need an additional sub(s) with the floorstanding speakers vs the the bookshelf speakers.
    Seriously, go to Best Buy and grab a set of the S60's and throw them in your room. That way, YOU will know, for sure, whether or not they're going to work for you in your room and and your electronics. If they don't, you can return them easily in the time frame of the return window / return policy.
    halo wrote: »
    Keep an eye out for "Scratch & Dent" prices on the Signature Series, especially the S60's. I purchased my set from Crutchfield (you can get the brown walnut or the black walnut from them). With the floorstanding speaker design, you don't need to build the stands and floorstanding speakers are actually easier to drive than bookshelf speakers. Again, the downward firing power port really makes placement versatile and easy compared to rear ported in your small room. To me, the Signature Series is a no-brainer here. That'll also free up some room $ if you decide to drive them with some high(er) end electronics. Win/Win.
    If I was gonna get the Signatures, I would just keep the LSis, because they are the better speakers, right?
    I want to get a pair of speakers that is an upgrade (I don’t know if the Signatures are better than the LSis or not, but I don’t think it is), and I want the usefulness of a bookshelf speaker (say we move to a space where we dont have room... boom! Nearfield setup!).
    I also don’t know if I will be able to sit far enough away from the Signatures to no time hear the drivers individually. I usually sit around 8 feet away from the mains, is that far enough?
    Thanks again,
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    edited June 11
    So today I had my friend over, and as I was attempting to impress him with the bass response of system, one of the Missions surrounds came off of the woofer. So as of right now I’m stuck pretty much dead in the water, but I’m hoping to get it replaced soon. However I think I may just get new speakers. I don’t know if I should go with the Signatures or the LSiMs. I may be able to stretch my budget just enough to get 705s, but I’m not sure. I don’t know how much a refurb pair would cost when you factor in the Friends and Family sale.
    So any suggestions on fixing the missions? And Signature S60s or LSiM 705s/703s? (Still not 100% sure if the 705s are a possibility)
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • ClipdatClipdat Posts: 3,562
    So was he impressed by that?
    mlistens03 wrote: »
    Got Dayens?
  • mhardy6647mhardy6647 Posts: 17,646
    I had 6SN7 immolate one evening while playing the upstairs hifi for a friend from Massachusetts. That was a tad embarrassing. :|
    On topic ;) Are the woofer surrounds polyurethane foam (as opposed to butyl rubber)? The polyurethane surrounds "dry rot" (so to speak) over time and do need periodic replacement. Replacement is (as they say in the mathematics textbooks under some proofs) straightforward* and inexpensive.
    I don't even know which Mission loudspeakers you have @mlistens03 but chances are they can be rehabbed without undue drama.
    Note, I am not trying to discourage you from getting new/more/better speakers**, just providing a little context.
    ______________
    * Should be easy compared to, say, turning a pen blank!
    ** I would never do such a thing ;)
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
    Clipdat wrote: »
    mlistens03 wrote: »
    No, he said there wasn’t enough bass. :lol:
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    Got Dayens?
    edited June 11
    ______________
    I have Mission 770 Freedoms, which have butyl rubber surrounds. I will still restore these speakers, but I don’t know if I should get the newer speakers first. I have done surround repair before on my Infinity Crescendos (which I am selling), and I know it’s pretty straight forward, but these speakers are, TBH, pretty much worthless. A flawless pair sells for $100, and these ones are trashed.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    Clipdat wrote: »
    Holy bass, she could park a Yugo in her mouth.
    HELLO...HELLO......HELlow.....HEllow...Hellow....hellow.... :o
    So going back to the original point of this thread, I want to buy LSiMs, but given my taste, I don’t think they are the speaker for me. I like my LSis but I feel like they need more treble to be a speaker I would keep around, and I read that the LSiMs are even more laid back. So do you guys have any suggestions? I know I’ve asked this several times, but I feel like I have given you more info on what I like.
    I would prefer not to have to integrate a sub, but if I do then no big deal.
    I would like it to be on the brighter side of things, although as long as it isn’t super laid back, then it is ok.
    I want really good clarity.
    I’m not going to give a price area because I haven’t sold anything yet, but let’s just set the absolute limit around $650.
    Also, do you guys think that it would be better to just fully restore my Mission 770s and then replace my electronics?
    I know I’ve asked this question before, and this will be the last time, but I’ve never told you guys my taste in sound, and in order to get the best suggestion, I think that is necessary. This will definitely be the last time I ask for suggestions on what to get.
    Thanks so much,
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    edited June 14
    Do you like Klipsch?
    Edit: I'm honestly just asking that as a seriously question. I re-read it and thought it might be viewed as sarcastic, but it's not. Personally, I like the sound of Klipsch speakers.
    Got Dayens?
    Clipdat wrote: »
    I don’t have anything against their older offerings, although I’ve heard that the horns tend to “ring” and generally sound bad, although I’ve never heard them in person so I don’t really know. I don’t like their newer stuff since they were bought by Audiovox, it all seems to have very high failure rates.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • Viking64Viking64 Posts: 2,540
    Micah, I know people have mentioned this in other threads, regarding interconnect cables, and you seem hot to buy new speakers, but if I remember correctly, you currently have two sets of towers of some sort in your rig.
    I would suggest that buying a $40 set of Blue Jeans interconnects and running them from your CD player would make more difference in sound quality than the aforementioned speakers would, based on your current cables.
    Heck, if you don't get any offers that pan out, I would be happy to ship you a pair of LC-1's gratis. (There's some Latin schoolwork for you.) :p
    edited June 14
    Where did you hear that their horns ring and sound bad?
    mlistens03 wrote: »
    Micah
    Got Dayens?
    edited June 14
    Another inexpensive brand of cables to consider are Signal Cable. Club Polk members get a discount. Just be sure to mention that you're a member here before you purchase.
Howdy, Stranger!
