The Tale Of 3 Tweeters
Let me start off by saying that I have been using a pair of SDA 2B's since the mid 90's.
I have used the SL2000, the RDO194, and currently, the SL2500, which I find to perform the best.
With the 13Khz peak of the SL2000, and the ringing of the RDO194, plus the rather rough crossover point between the drivers, I have not been completely happy until now.
The SL2500 is smoother and more transparent, with better timberal accuracy, with a small trade-off of being a bit thinner in the low presence range do to using these tweeters without the added capacitance.
I have run various frequency sweeps, and haven't found any obvious holes in the response.
  • F1nutF1nut Posts: 39,620
    It's the wrong tweeter, period.
  • mlistens03mlistens03 Posts: 1,016
    edited June 10
    What he is trying to say is that that is not the correct tweeter for that speaker. It could cause a number of issues, the biggest being a weird impedance, weird phase, a wonky frequency response, and possibly (extremely unlikely) damage to your crossover. Probably not the best idea. Not saying that it won’t work, but it won’t work as well as the original or the RD0 drop in replacement.
    F1, you’ve gotta go into a little more detail when you explain things. I know I would not listen to someone, who when I asked a legitimate question, just said “you are wrong” and left it at that.
    Micah
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • SoundMann1SoundMann1 Posts: 9
    There hasn't been any negative issues so far. My amp is stable, and the speakers are smoother and more balanced than ever before!
    The SL2500 measured @ 6 Ohms. what is the resistance of the SL3000?
    Are there only a few people hanging out here anymore?
  • xschopxschop Posts: 803
    Can you expound on the "ringing" RD0194's?
  • FestYboyFestYboy Posts: 2,326
    More than anything, the issue is using a TL Tweeter in a non-TL speaker. The XO hasn't been modified to use a 2500 properly. TL mod the XO, and then you'll understand, and also want to grab a pair of 198s.
    xschop wrote: »
    Ringing is caused by stored energy that is not dissipated by the diaphragm in a timely manner.
    The trilaminate tweeters were successfully designed to solve this.
    FestYboy wrote: »
    That wouldn't be entirely correct, as the official specs leave a lot to be desired.
    FestYboy wrote: »
    I already understand what this mod entails.
    FestYboy wrote: »
    That would be a downgrade to the tweeter series I like the least!
    Anyway, the tweeters appear to have a crossover point of around 2.3Khz in this circuit, which appears to give a fairly close to optimal blend between the drivers.
  • boston1450boston1450 Posts: 5,908
    mlistens03 wrote: »
    Micah
    LMAO
    Randy in Maine
    CRS+ TL'd 198 tweets
    RTA15 TL'd198 tweets
    All TL upgrades by WMG
    Cs1000p - MIT speaker cables
    Pangea power cords
    SoundMann1 wrote: »
    FestYboy wrote: »
    FestYboy wrote: »
    FestYboy wrote: »
    He is entirely correct and the schematics leave nothing to be desired.
    This ringing you're talking about does not exist. You're the only one hearing it.
    Stop trying to reinvent the wheel, it's already been perfected.
    mlistens03, would you like to buy a vowel?
  • ken brydsonken brydson Posts: 6,938
    C'mon he's 14. Do you not remember Sid the kid back in the day
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
    Sid the kid was smarter.
    I wasn't referring to any schematics.
    I hear it, therefore it exists!
    These speakers are far from perfect!
    Must be your tinnitus.
    Ouch.
    I tend to be very careful with the volume, in order to keep that from happening.
    Sorry F1, I probably shouldn’t have said that, but I think that if you explained a little more, it would be a lot more helpful.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    Actually, ringing is a well known phenomena which plagues soft-dome tweeters, and it just so happens that the manufacturer of the SEAS/RDO tweeter created a new type of tweeter just for those whom the ringing bothered!
    Ironically, they call it a ring tweeter.
Howdy, Stranger!
