Outdoor patio system question
DabutcherDabutcher Posts: 1,520
I currently have four JBL Control 25 speakers set up in my patio area. Fed by a Pioneer Elite receiver. Seems to sound good for music and movies. But low end is lacking. My idea is to buy these two JBL subs to add to the system . I would build a cabinet for them instead of in wall application. Any ideas about my idea or ideas about a better set up? Thanks. Drp02mn7601oj.png
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • WillowWillow Posts: 8,912
    Fwiw I have 4 atrium speakers and a neighbour behind me said many times last summer to turn it down because the bass was shaking inside his house. I call bs on that. All that to say just be careful with the low end but I'd like some more in our system too.
    2Ch- B&W 703, SVS PB10 NSD, Marantz NR1607, Parasound 1500a, Pro-Ject Debut Carbon (Yellow) with Acrylic platter, Pro-Ject phono pre, MIT AVT 2 speaker cables, MIT AVT 1 and AVT 2 ICs, XLO Jumpers, Tributaries Optical, Signal Cable Magic Power Cables x3, Samsung 55JS7000, Harmony 1100, Sony BDP-S6200, Rotel RDV 1045 (as Transport), Cambridge Audio DAC Magic100, Monster 3600MKII and Android MXQ PRO. - Pool /Gazebo Yamaha RX-A1010, Polk Patio 25x4, MIT AVT3 ICs
  • JaybeezJaybeez Posts: 651
    Depends on how much low end you want, but I have a set of Atrium 5s with one of these: https://www.polkaudio.com/products/atrium-sub10
    Sounds pretty darn good to me, and sub has been part of my outdoor system for 7 -8 years. Of course I'm in So Cal with milder weather, so your mileage may vary.
    Living Room (HT):Denon AVR X-3000 ; LSiM 703 ; LSiM 704C ; FXi4s ; Sub – Rhythmik F12SE
    2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Ascend Acoustics Sierra 2s ; Polk PSW 350 Sub
    "And these children that you spit on, as they try to change their worlds, are immune to your consultations. They're quite aware of what they're going through."
  • stretchlstretchl Posts: 789
    @Jaybeez Where do you have your sub placed in relation to your speakers, walls, etc? I'm setting up a Sub10 in a few days. It's my first time using a sub. I've read that they should be in a corner, or along a wall to create the most resonance. Any thoughts? Thanks.
    Hi-Fi
    Apple Lossless --> Squeezebox Touch --> Grant Fidelity TubeDAC-09 --> MIT AVT2 IC's --> Yaqin MC-10t --> MIT EXP S2 Cables --> LSiM-705's
    In the Bullpen
    Adcom GFA-555ii
    Luxman R-115
    Visuals
    http://StretchPhotography.com
  • mlistens03mlistens03 Posts: 986
    stretchl wrote: »
    What I do when I place a sub is set it in the listening position, and then walk around and go to all of the potential places to put it. Then, whichever sounds best, put it there and when you sit in the listening position, you have that same bass.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
Howdy, Stranger!
