Super Mario Jump Sound
I have SDA 2B studios powered by an Adcom GFA 555. When I power down the amp, about ten seconds later there’s a little squeal from the right channel that sounds just like Mario jumping. This wasn’t there when the speakers were wired directly to my Yamaha RX-V1800. Any ideas? The DC offset is 7 and 38mV
  • ClipdatClipdat Posts: 3,562
    Sounds like typical Adcom power down transients.
    Got Dayens?
  • codycatalistcodycatalist Posts: 1,373
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Yamaha AV34
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
  • boston1450boston1450 Posts: 5,908
    Are you turning units On/Off in the correct sequence?.... (Turn On) Preamp/receiver before amplifier.... (Turn Off) amplifier first wait 20-30 seconds for it to completely power down n then turn off the pre/receiver. Just a thought
    Randy in Maine
    CRS+ TL'd 198 tweets
    RTA15 TL'd198 tweets
    All TL upgrades by WMG
    Cs1000p - MIT speaker cables
    Pangea power cords
  • Tony MTony M Posts: 5,364
    Here's his I guess;
  • AdamSDCAAdamSDCA Posts: 16
    Sounds like it’s normal. I’ll try the different power-down orders to minimize but as long as it’s not a symptom of some ominous issue then I won’t worry about it. Thanks!
    Ive heard Adcoms do this. My 555 never did & it matched well with sda2bs well. Im no tech. It never hurts to check all connections & clean all cables/wires (we sometimes over look tiny things). I would test amplifier on another & see if it FOLLOWS & then you will know. Sometimes it can be fun to play with audio :) Good luck n report back. Lot of Adcom fans here
    Randy in Maine
    Pangea power cords
Howdy, Stranger!
