The Tale Of 3 Tweeters
Let me start off by saying that I have been using a pair of SDA 2B's since the mid 90's.
I have used the SL2000, the RDO194, and currently, the SL2500, which I find to perform the best.
With the 13Khz peak of the SL2000, and the ringing of the RDO194, plus the rather rough crossover point between the drivers, I have not been completely happy until now.
The SL2500 is smoother and more transparent, with better timberal accuracy, with a small trade-off of being a bit thinner in the low presence range do to using these tweeters without the added capacitance.
I have run various frequency sweeps, and haven't found any obvious holes in the response.
Sony GX900ES, Micromega Stage 3, Micro Seiki BL-51/Grace 707 MKII/Signet TK7e, Polk SDA 2B's w/SL2500's, JVC HA-D990.
«13456
    F1nut Posts: 49,802
    It's the wrong tweeter, period.
  • mlistens03
    mlistens03 Posts: 2,767
    edited June 2018
    What he is trying to say is that that is not the correct tweeter for that speaker. It could cause a number of issues, the biggest being a weird impedance, weird phase, a wonky frequency response, and possibly (extremely unlikely) damage to your crossover. Probably not the best idea. Not saying that it won’t work, but it won’t work as well as the original or the RD0 drop in replacement.
    F1, you’ve gotta go into a little more detail when you explain things. I know I would not listen to someone, who when I asked a legitimate question, just said “you are wrong” and left it at that.
    Micah
    xschop Posts: 4,702
    Can you expound on the "ringing" RD0194's?
  • FestYboy
    FestYboy Posts: 3,861
    More than anything, the issue is using a TL Tweeter in a non-TL speaker. The XO hasn't been modified to use a 2500 properly. TL mod the XO, and then you'll understand, and also want to grab a pair of 198s.
  • boston1450
    boston1450 Posts: 7,472
    mlistens03 wrote: »
    Micah
    LMAO
    Randy/Maine
    F1nut Posts: 49,802
    SoundMann1 wrote: »
    FestYboy wrote: »
    That wouldn't be entirely correct, as the official specs leave a lot to be desired.
    FestYboy wrote: »
    I already understand what this mod entails.
    FestYboy wrote: »
    That would be a downgrade to the tweeter series I like the least!
    He is entirely correct and the schematics leave nothing to be desired.
    This ringing you're talking about does not exist. You're the only one hearing it.
    Stop trying to reinvent the wheel, it's already been perfected.
    F1nut Posts: 49,802
    mlistens03, would you like to buy a vowel?
  • ken brydson
    ken brydson Posts: 8,650
    C'mon he's 14. Do you not remember Sid the kid back in the day
    F1nut Posts: 49,802
    Sid the kid was smarter.
    F1nut Posts: 49,802
    Must be your tinnitus.
  • mlistens03
    Ouch.
    I tend to be very careful with the volume, in order to keep that from happening.
    Sorry F1, I probably shouldn’t have said that, but I think that if you explained a little more, it would be a lot more helpful.
  • Llama56
    Llama56 Posts: 2
    Is the RD0194-1 tweeter a better sounding tweeter than the SL2000 unit in my Monitor 10's. I am being told that the RD tweeter is smoother than the SL. I'm thinking of purchasing the RD's at $108 but need to know if it is worth the cost?
    F1nut Posts: 49,802
    Worth ten times the cost.
    mhardy6647 Posts: 33,046
    Oh. I just LOL'd.
    Almost spewed iced coffee, too.
    nooshinjohn Posts: 25,100
    I need to stop opening these threads without making popcorn first....
    F1nut Posts: 49,802
    edited July 2018
    SoundMann1 wrote: »
    I still contend that the best mod I have made to my 2B's is adding SL2500 TriLaminate tweeters!
    It's the wrong tweeter for the 2B's.
    F1nut Posts: 49,802
    SoundMann1 wrote: »
    The only drawback is 4-Ohm impedance.
    Like I said, it's the wrong tweeter.
    F1nut Posts: 49,802
    That's fine, I just want to make sure no one else makes your mistake.
    FYI, you can't even call them TL'd as the crossover hasn't been tweaked.
