Need a recommendation
    nooshinjohn Posts: 25,034
    edited June 2018
    gudnoyez wrote: »
    Ha Russ and myself are about a hour and a half away we could go to Wisconsin first get some of that Linenkugel brew John's been yammering about and meet you at the Ulyeses Grant mansion then head to Grant park get liquored up then drop you and the missus back off at the Goldmoor. What you say Tony who's your buds?
    Just make sure youse knuckleheads send me a 12 pack... UNOPENED!!!
    pitdogg2 Posts: 24,477
    gudnoyez wrote: »
    And there goes all the fun..... party pooper.
  • cfrizz
    cfrizz Posts: 13,415
    tonyb wrote: »
    txcoastal1 wrote: »
    tonyb wrote: »
    No view Ivan, gotta have a view.
    Russ set you up with a room with a view, and you complained about it...jeez you picky
    LOL, yeah man, if I was a different kind of animal that would have been sweet.
    Something more along the lines of this.
    http://www.goldmoor.com/lodging-amenities/rooms/the-suites/mississippi-suite/
    Anything else in the area I should be looking at ? Off the beaten path joints ?
    Tony, that looks great, just go with that, since it seems to have all of your wife's requirements. It should be obvious by now that these guys are clueless.
    cfrizz wrote: »
    Should also be obvious we are busting the man's chops a little bit...
  • erniejade
    erniejade Posts: 6,288
    Just to to a sybaris and spring for the chalet room.
    Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
    tonyb Posts: 32,902
    cfrizz wrote: »
    LOL, no worries. I can take it as well as I dish it out. Just thought some of the more local guys would have some input.
