Upgrade hdmi cables or not
  • pitdogg2pitdogg2 Posts: 10,234
    mlistens03 wrote: »
    Ooohhh ok. I see now. So it just reduces the noise floor. Interesting.
    delkal wrote: »
    But the Dac only reads zeros and ones. This is processed and decoded, then a new analog signal makes it out. There is no trace of the original digital signal after processing. Why would you expect a small amount of noise picked up by a digital cable to come thru?
    This is what keeps bugging me about digital cables, it’s only 0s and 1s and I don’t think that that noise is gonna be either a 0 or a 1, at least it’s very unlikely methinks. Analog cables yes, it’s gonna reproduce everything but I still don’t totally understand.
    People didn't think fiber optic cables made a difference as long as light made it through. But it's now known that how the cable is made from the type of fiber used to the terminations all made a difference in the way the information gets there.
    The way the packets of ones and zeros are sent and received makes a difference.
  • rpf65rpf65 Posts: 1,720
    Not really hard to understand how a good quality HDMI cable can transmit data cleaner than a cheaply made one.
    First it isn’t just a single one or zero, but a string of them. Then think of the string as a staircase. When you have a perfect transmission, sound and picture is pristine.
    Like a staircase, a little noise acts the same as an uneven riser. Tests have shown a step that is 1/4 of an inch higher or lower will cause people to stumble.
    If noise is introduced into the transfer signal, it corrupts the data. No getting around noise in any type of recording. Just the act of filming or recording introduces noise. Every step after that introduces more noise, until you finally see/hear the end product.
    Quality HDMI cables tend to add less noise, be it from the connection, interaction between the bundle of cables, or general atmospheric rf signals.
    Better shielding, better conductors, and better termination are what you pay for. As always there is each individuals limit on price for performance. Then there is the source and display/speakers.
    A budget tv, using the onboard speakers will see negligible results from a higher end cable. The higher end TVs and we’ll constructed surround systems will show both visual and audible improvement.
    Not saying it will be night and day difference to every individual, but many, if not most people see or hear a difference.
  • ManticoreManticore Posts: 278
    I was using generic HDMI cables for a few years. I found most of them work. I was having hand shake issues between my BR & my Denon AVR and sometimes between my cable box and AVR. There were intermittent black outs and dropped audio.
    I thought it was the HDMI board in the AVR. This was also happening after i replaced the BR player with a 4K player. I decided to buy a few AQ forest cables and it has been a few months now with no drop outs of audio or video. After hooking up the new HDMI forest cables i feel the picture is brighter and sharper with what seems to be increased sound. I noticed this immediately upon installing the new cables.
    I am currently short two cables. One from the HTPC and one from the cable box to the AVR. I will be replacing both of them within a few days to AQ Forest cables. I also use a USB A to B - Cinnamon from AQ and like it very much. Like speaker, ic cables it does make a difference. It has for me!
    Denon AVR X4200W
    Parasound HCA 1500A amplifier
    Adcom GFA 555 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    NAD pp 4 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk RTiA 7's
    Polk CSi A6
    Polk RTiA 3's
    Polk SDA 1C's modded
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • dolbyddolbyd Posts: 263
    edited April 28
    I settled on the Chocolate line of AQ for the HT. I had the Cinnamon and moved them to the MB. Both great cables.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 7704, OPPO 203, Emotiva XPA-5 Gen2, Emotiva X-500,X-150, Sony 75" 940E, Panasonic Plasma VT50,PS Audio Power Port X2, Perfect Wave AC-5 x4
    Office- Infinity Kappa 600, Kappa Center, in ceiling Polk RC80i, SVS PC 2000, Marantz 5010, OPPO 203, Emotiva X300, Sony 48"
    Master BR- LSi7, LSiC, LSI700 in ceiling, SVS-PC 2000, Marantz SR5012, Adcom 7500, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" 800B
    Workout room- RT2000P, CS1000P, Pioneer Elite SC81, OPPO 103, Panasonic Plasma VT 42"
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    Storage room at this time- LS90, RT16, CS350LS
  • F1nutF1nut Posts: 39,991
  • headrottheadrott Posts: 5,293
    Agreed Jesse. I have 2 MIT cables, one to the T.V. and one for the projector in the home theater (which is 25 ft.) and have never had a problem with either getting the signal from the source to the projector. I have only used the MIT cable in the theater, but have used 3 different cables on the T.V. and noticed an improvement with color saturation, black levels, and tint when using the MIT on the T.V.
  • mantismantis Posts: 14,942
    I use Carbon , Cinamon and Chocolate in my system. For 4k Stuff high end Projectors , we have a Sony Laser 4k using a Cinnamon and all Cinnamon for all sources and compared to the Forest level cables is very minimum gain in clarity detail and sound.
    I have to agree with everyone above stating the Cinnamon is the sweetspot and very little to no gain after you go higher end then that especially considering the quality of your components and size of your display. We have a 138 inch 2:35 Cinascope Stweart Screen with the Sony Laser 4k Projector and even there I couldn't tell the difference between Cinnamon and Carbon, Chocolate. Very little gain over the Forest which is probably the best bang for your buck HDMI cable on the market. I think the Forest for those who don't care to spend a small fortune on HDMI cables is a excellent quality cable for TV's put o85 inches 4k display and up to the high end. I still suggest if your willing to spend a couple extra bucks go Cinnamon as they do have a slightly better picture. You will have a hard time noticing it and hearing better sound quality unless you have a higher end system and display.
    Digital as any signal transfer needs to be done correctly and to spec, after you reach the proper requirements little can be done if any to improve anything in the digital world. Analog is different as you can use cabling to tune your system with limitations in cable performance.
    Dan
  • firsttimerfirsttimer Posts: 87
    Thanks everyone as usual who has contributed to answering some of my questions. I will be slowly upgrading my HDMI to cinnamon AQ hopefully starting in the next couple of weeks. Thanks everyone
  • afterburntafterburnt Posts: 4,425
    Any opinions on what cables sound the best?
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • mhardy6647mhardy6647 Posts: 18,404
    edited April 29
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • txcoastal1txcoastal1 Posts: 9,786
    Go tell George that :/
    He's got machines that make the special cable symmetries. The parts are hand made and very expensive to replace
    It was meant humorously -- but it wasn't humorous, so I blasted it prophylactically :|
    I know, but thanks to the Rooster I was able to have dinner a couple times plus brews with Colleen Cardas who was the ops mgr at the time. Great info and history of Cardas
    afterburnt wrote: »
    Don't really think HDMI cables influence sound, so probably isn't a best cable out there. Better quality HDMI just enable better signal transfer and reduce noise interference.
    Depending on the quality of your individual display, it may increase picture clarity and color rendition. More times than not, handshake issues are from a bad or inferior HDMI cable. Cleaner data transmission will also make audio clearer and more dynamic.
    As far as influencing the sound signature of your HT system, other than lowering the noise floor, I don't think there is any coloration or lack there of.
    afterburnt wrote: »
    I find the Audioquest HDMI cables to sound the best. Pick whatever level you can afford. My Vote is for the Cinnamon level as it's where I feel price meets performance in a way that can't be beat.
    Dan
    rpf65 wrote: »
    afterburnt wrote: »
    That's what I want is to lower the noise floor I don't care about the picture. No matter how clear the picture I still see two TV's.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Seeing two objects, when only one is present, is normally a symptom of too many adult beverages.
    So I finally installed the cinnamon HDMI cable from my blue ray to the display. There is a noticeable difference in colour, detail and I would say contrast. I have watched dead pool, ghost in the shell, and justice league with the new HDMI cable. Noticeable difference on all movies. Even had a friend over last night and he even noticed the difference. Now I just need to upgrade two more HDMI from 4K box to receiver and to display. I was using the mono price 4K rated cable prior to going to the cinnamon Audioquest HDMI.
    Sweet man I really like the Cinnamon Cables. If I wasn't all outfitted in Carbon I would have absolutely no regrets going Cinnamon level cables. I find the Carbon not to make a big enough difference vs the amount of money you pay more. This is why I say the Cinnamon is such a great value vs performance vs all other HDMI cables.
    The Forest also performs well above it's asking price, nothing wrong with using them either. Well built very affordable and works flawlessly with Dolby Vision and HDR 4k stuff.
    I use a Cinnamon up to the TV and Carbon for everything else.
    Dan
    Yes I am really impressed with this cable at this time. As said will be upgrading the final two when I can. Watching dead pool now in hdr And the picture is so clear and detailed compared to the other times I have watched it.
    So my upgrade on cables is complete. I settled on cinnamon from 4K box to av receiver, cinnamon from av receiver to display. This has improved both audio and video from 4K box for regular cable tv viewing I was able to try a chocolate HDMI so I hooked it up to 4K blue ray player directly to display and must say I really like this cable. So I am going to run one chocolate from 4K player to display directly. So if anyone is wondering how these cables are I can tell you they work fantastic and I have been very impressed with both the cinnamon and chocolate cables. If your on the fence I say you cannot go wrong with either cinnamon or the chocolate AudioQuest HDMI cables. Well worth the upgrade from my Monoprice cables.
  • mrlorenmrloren Posts: 1,409
    Can't go wrong with Audioquest cables. Might cost a bit but just can't go wrong.
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk 80 F/X RT
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • tonybtonyb Posts: 29,315
    firsttimer wrote: »
    Good for you, glad your enjoying them.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
Howdy, Stranger!
