LSI25 amp problem
So yesterday I picked up a pair of Polk LSI25 speakers at my local goodwill, and when I fired them up this morning, the sub in the right speaker wasn’t working. I decided to pull the amp board and take a look inside. The fuse was blown so I replaced it and plugged it in, and immediately one of the things that are the actual amps (can’t remember what they are called all of the sudden, it is one of the four pieces on the side of what I believe is a heat sink) began smoking. I don’t know if the amp powered on when I did that because I was paying to much attention the smoke, but does anyone know what could be the problem and how I could fix it?
Thanks,
Micah
2 channel
Speakers: Mission 770 Freedoms
Integrated amp: Technics SU-v75 and matching tuner
CDP: Technics SL-PC20
Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
TT: Technics SL-3200, direct drive
Cartridge: Shure M97xE
Pc gaming setup
Receiver/amp: Yamaha RX-V665
Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
Speakers: Boston Acoustics CR75s
Random equipment on standby:
Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
txcoastal1 wrote: »
You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
  • mlistens03mlistens03 Posts: 1,405
    I think I posted this in the wrong place. Sorry!
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • KennethSwaugerKennethSwauger Moderator Posts: 6,523
    Hello,
    The bass amplifier would have to be repaired or replaced, telephone Polk tomorrow at: 1-800-377-7655 select option 2 for parts.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Airplay355Airplay355 Posts: 4,205
    Somebody dumped Lsi25 at Goodwill? Lucky find, broken or not!
    Ikr? I got them for $50!
    Thanks guys, I will
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    While I was here I thought I would ask, I currently have a Yamaha amplifier that only is able to go down to 6 ohms, will this be a big problem that I have to fix ASAP or something that can wait?
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    Sorry to bump an old thread, but I decided that’s probably better than a new one :smile:
    I got to really looking at this amp yesterday, and I think I might have found a blown resistor, but I’m not 100% sure. It looks a little cooked, but then at the same time it looks like some [email protected] just got on it. Do you guys think this guys is blown?
    I fall you think it is, do you know the values of this resistor? I can’t figure out how to read it, because everything I find on the interwebz doesn’t agree with what I see on that resistor.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • pitdogg2pitdogg2 Posts: 10,217
    edited May 19
    Which one are you referring to?
    Give us a number. Usually a cooked resistor is very easy to tell.
  • F1nutF1nut Posts: 39,972
    20k ohms 1%
    I don't think that resistor is cooked though.
  • txcoastal1txcoastal1 Posts: 9,775
    If I remember correctly, when my board went out it was around the rectifier
    Sorry I forgot I’m looking at R80, looks like it either is slightly browned or has some form of crap on it.
    Where is the rectifier on the board? I’ve heard of that type of component before, but I don’t know what it is or looks like. Would this be the amp chips on the side of the heat sink?
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • msgmsg Posts: 4,196
    M - was just curious, did you ever have this amp repaired? Are you having a problem with it now, or just having a look around?
    It didn’t work when I bought it, and I never got it repaired. I want to try fixing it now, so that it’s will work for the time being, and then they will be worth more when I sell them. I was just looking inside to see what I could see, and test caps/resistors and stuff.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    The rectifier and heat sink I was speaking of, is between the blue capacitor S0143 and the brn/yel cable connector
    I decided this was the thread I should post this in, I found this in my wallet from the LSis:
    I guess I stuffed it in my wallet after buying them and forgot about it.
    I’m going to use this as an opportunity to say thanks so much for everything. Thanks for the help everyone, thanks Nightfall for the cartridge for my TT, and most importantly; thanks everyone for the memories.
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • FestYboyFestYboy Posts: 2,521
    That sounds very much like a goodbye...
    I hope I'm wrong.
    FestYboy wrote: »
    I hope I'm wrong.
    Oh you are wrong! You are right that sounds like goodbye! Oops lol sorry everyone for not noticing that.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
    Oh good.
    Now back to the task at hand: see if we can't get a service manual for that amp. Amps are fairly easy circuits, but when there's a preamp stage, filtering and shaping circuits, and power rectification, things can get weird and confusing quickly. Best to start on the power supply side, as it's the simplest circuit.
    I'll be getting knee deep in a NAD 7175PE's power circuit myself. It blows a 5A power switch fuse immediately, so a dead short is what I'll be after. From the sounds of it, the same is going to hold true for you.
    FestYboy wrote: »
    Oh good.
    Thanks! I think it is a dead short, because it blows the 5 amp fuse in about 2-3 seconds (I know it isn’t supposed to be 4 amps, but it was all we had on hand at the time). I’m slightly worried that the transformer is the problem, because according to the 3rd party repair guy’s eBay site, it isn’t the only part that can no longer be replaced.
    I have searched and searched the webs for a service manual, but I have yet to find one. Would Polk supplied me with one if I asked?
    Thanks,
    Micah
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
Howdy, Stranger!
