Audio Files
I am going to try HD Tracks for the first time. Thry want me to select either-AIFF, ALAC, FLAC or WAV. I don't no one from another. What should I do?
  • EmlynEmlyn Posts: 2,044
    The cost is the same regardless. Any of those versions can be converted to another version after downloading using JRiver or some similar media player. I just download the WAV version since it's the largest and universally supported, although it's entirely possible the files they have may have originated in the FLAC format when they received them from the music publisher. AIFF and ALAC are Apple specific formats, although they play on a Windows PC too. All are lossless formats, although ALAC and FLAC require "unpacking" on the fly for playback. AIFF is the Apple version of WAV.
    I usually convert a WAV file to FLAC and MP3 once I get it so I can use it on a portable player, in the car, on a smartphone, etc. I archive everything in the WAV format, so it's an easy decision for me to download the WAV files from HDTracks.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • ClipdatClipdat Posts: 3,450
    I usually go for FLAC because it contains metadata.
    Got Dayens?
  • LegenderLegender Posts: 443
    If you're not using apple products, then FLAC will work fine. If you're using iTunes/apple products then stick with ALAC.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • zuulzuul Posts: 170
    i use flac almost exclusively. if you are using a mac clementine is free... plays flac native... and imho better than itunes.... plus Wi-Fi remote available....
    speakers:
    bowers & wilkins 685 S2
    polk psw-10
    components:
    sonic frontiers line 1 preamp
    sonic frontiers anthem amp 1
    mac mini w/ audioquest jitterbug
    teac ud-501 digital to analog converter
    oppo dv-980h dvd/cd
    interconnects:
    monoprice
    guzi
    belkin gold series usb
    speaker wire
    audioquest type 4
    power:
    rhino-tek 1000w 15amp voltage regulator
    vansevers 211 power cord
    pangea ac-14 power cord
    tubes:
    amplifier: (2) NOS 1960 philco/lansdale 12AU7 (super rare!), (1) NOS 1967 mullard 12AX7, (4) 2016 svetlana hard blue EL-34
    pre-amp: (6) E88CC/6922 ??? (haven't cracked the case yet to see what previous owner was running...) so for now they are mystery tubes.
    misc:
    JRiver Media Center 24
    sanus 24" speaker stands
    auralex acoustics subdude II
    DeMoude Audio cylindrical bass traps
    rf/emi/noise reduction caps for empty rca inputs.
    Hall of Fame: [retired/sold]
    polk monitor series 5jr+ w/ RDO194-1 upgraded tweeters
    polk monitor series RTA 8T
    kenwood kd-550 w/ SME 3009 Series III tonearm grado gold cartridge
    adcom gfp-555II
    marantz 2238b
    luxman M-120A
    technics sl-b10
Howdy, Stranger!
