Polk Magnifi mini to Computer
Hello Guys,
My computer specs -
gigabyte b150m d3h motherboard
Asus XonaR DG sound card
R9 390 Sapphire Gfx card
Lg 27ud68p 4k monitor .
Issue -
I am unable to play 5.1 surround from the optical port of my xonar dg , i can play only 2ch sound from it. Do i need to upgrade my sound card or should i get some amp or DAC or anything else which will give me good 5.1 surround from magnifi mini . I heard that only HDMI ARC port connected to sound bar will produce 5.1 from it. But i doubt if my monitor or graphic card has it.
I am very much tired of finding perfect connections for perfect sound from this card.
I plaanned to get sound blaster z , but it is more for gaming and not movies , kindly suggest me the best setup only for movie and music .
Thankyou.
  • npk21
    npk21 Posts: 2
    Clipdat Posts: 12,599
    Use the HDMI output on your graphics card.
  • Manticore
    Manticore Posts: 408
    edited May 2018
    Is it possible your sound card only plays 5.1 surround through the headphones?
    "Dolby Headphone: technology allows users to listen to music, watch movies, or play games with the dramatic 5.1-channel surround or realistic 3D spacious effects through any set of stereo headphones".
    Otherwise open the soundcard options and look for output settings. I can choose, stereo,quadraphonic,5.1 or7.1output.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
