Monitor 7 Crossovers
Does anyone have a step by step or at least a shopping list/link of what capacitors are needed to redo crossovers? Looking for middle of road ~$50 or so. Open to options and opinions.
  • FestYboyFestYboy Posts: 2,521
    Start by putting a "1" in front of your budget... And don't forget about the resistors.
  • rmetz85rmetz85 Posts: 14
    FestYboy wrote: »
    LOL. I’ve heard lots of people have done them for around $50 or so. Also heard don’t have to do resistors. However I’m open to seeing what you suggest.
  • F1nutF1nut Posts: 39,969
    The values are printed on the components.
    Caps:
    12uF 100V or higher
    34uF 50V or higher
    Resistors:
    2.7 ohm 5 watt or higher
    4.5 ohm 5 watt or higher
    Use either Sonicap Gen I or Clarity CSA for the 12uF. The 34uF shunt cap many will say isn't important, but I disagree. However, you could use a cheaper cap there if you have to.
    For the resistors gets Mills, either 10 or 12 watt. Yes, you absolutely need to upgrade those.
  • FaustinFaustin Posts: 730
    ^^^^ Plus one. You can use a Dayton cap for the 34uf if you want to keep your budget down.
  • tonyp063tonyp063 Posts: 368
    This is the dry-fit picture of set of Monitor 7s I did a few months ago.
    Mid-tier components.
    $140 in parts, including binding posts. PM me if you want the list.
    tonyp063 wrote: »
    Noticeable before and after performance?
    Faustin wrote: »
    How much of a difference is there in price and performance?
    rmetz85 wrote: »
    Absolutely.
    Note.
    I have done a pair of Monitor 10s with Dayton caps. While they did sound better than the old, dried out caps that were in them originally, the better quality ones made that much more difference. They got Sonicaps before I gave them to my daughter.
    You get what you pay for, as the saying goes.
    Standard disclaimer. My ears. My room. My electronics. Yada yada yada
    edited May 23
    edit:
    double post
    tonyp063 wrote: »
    Not sure how I PM in this...just joined, but I’ll take that list.
  • mlistens03mlistens03 Posts: 1,405
    edited May 23
    Scroll to the top of the page and click the pic of the letter, then select new.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    rmetz85 wrote: »
    PM sent
    I went ahead and got the parts. Did the same build as Tony, less the posts as mine were still nice.
    Install seemed easy enough. Hooked them back up and everything worked! Haha. I was nervous as heck!
    I will say they sound so much more balanced. I’m really looking forward to seeing what they sound like once worn in. Wasn’t a drastic difference from before, just more balanced. Should I get Better quality once played more?
  • lightman1lightman1 Posts: 9,644
    rmetz85 wrote: »
    Without question.
Howdy, Stranger!
