Stainable Wood Filler
    nooshinjohn Posts: 25,094
    Me thinks somebody needs to stop sniffing the fumes off the stain can...
  • jdjohn
    jdjohn Posts: 3,000
    A friend of mine, who has done lots of restorations, swears by baking soda and super-glue as a filler. I have not tried this myself.
    Just saying that two people that are professionals in any field will not always agree on everything, so no reason to trash the thread over something as stupid as preferences in wood glue.
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2018
    I hope Gorilla Glue isn’t bad as I just ordered a small tube to fix the foot on my Egyptian Walking bowl.
    Post edited by BlueFox on
    F1nut Posts: 49,794
    BlueFox wrote: »
    I hope Gorilla Glue isn’t bad as I just ordered a small tube to fix the foot on my Egyptian Walking bowel.
    Wrong glue. 5 minute epoxy would be a better choice for ceramic.
    txcoastal1 Posts: 13,132
    BlueFox
    10:33PM
    This is disturbing
  • BlueFox
    Well, I can try the Gorilla and if it doesn’t work then order the epoxy. Thanks.
  • BlueFox
    txcoastal1 wrote: »
    BlueFox
    10:33PM
    This is disturbing
    LOL. Freudian auto correct. :o
    I will edit the post. :)
    Gorilla glue, unless clamped, will expand significantly as it cures, depending on formulation. this will force the pieces apart, and yes, I know this from experience.
    Viking64 Posts: 6,679
    Now I want an Egyptian walking bowl. :/
    I am sure Jesse still remembers how to form one, but I don't think he has worked with that material since he was a construction foreman for King Tut.
    billbillw Posts: 6,185
    I agree that gorilla glue is not the best when you want a tight, fine seamed bond. I've used it many times and it does foam up and push things apart. It has its place, but not in repairing a fine piece of ceramic pottery/artwork.
    For rig details, see my profile. Nothing here anymore...
