Sony x850e 65" hdmi questions
Tony. The Panamax is on the bottom of the rack on a glass platform the led’s burnt out on it so you can’t see it lit up. Tv. Receiver sub, as well as the cable box coax runs through it.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Hmmm, how do you know it's still working at all then ?HT SYSTEM-
lsi 9's -
Yep. Its working. The power lights still work and i turn the sub on and off with the delayed on power. The twin 12" sub box doesnt auto offMusical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
What was said about Audioquest HDMI cables is true. under 8M.
About universal mounts. They are not all created equal. Most of the cheaper mounts suck. I hate them all due to input blocking and poor built quality. Some make you assemble the entire mount which takes forever.
I stick with quality mounts from Peerless, Omnimount, Chief and Strong from Snap AV. All these companies make fantastic mounts. Yes they cost a bit more but they hang on the wall level, don't block your inputs for the most part, come ready to go.
Using a power kit for your power is the way to do. Power cords are NOT in wall rated and can cause a fire. If you have a fire your home owners insurance will void and you'll be left with the bill.
A power kit uses romex between the outlet at the TV side and the Inlet at the equipment side.
Another benefit is the fact you now have a in wall rated extension cord for your Tv and you can plug it into your high quality surge protector.
However you can install an electrical outlet and then buy a Flat Panel Surge protector from Panamax , surge X etc but if you already have a high quality surge for your equipment, that is the better way to go and more affordable.
Congrats on the 850E , for the money it's a fine set. Once you see 4k go, you'll get addicted. 4k is supposed to be coming this year to cable companies. Comcast already has a 4k box out now but no service behind it yet. Thats on the way.
Verizon is working on their setup as we speak and I keep bothering them about it.
DSS also has a 4k box with very little content. No Broadcast yet but also coming soon.Dan
Thanks for the advice and mount brands. I had no idea there was so many different mounting styles for an on wall bracket. This has definitely been a learning experience.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
