Stainable Wood Filler
kevhed72
I am staining our deck and already tried 2 type of wood fillers for screw holes and imperfections. Both trys yielded a much lighter color of filler than the stain itself....what am I missing here???
Filler never takes color the same, mainly because it's not wood. Using wood plugs with the grain going in the same direction would get you closer, but what a PITA.Political Correctness'.........defined
President of Club Polk -
PITA should be printed on the can of wood filler. I know someone who claimed there is a special filler to be stained over but I cant find it!
Just use pieces of old underwear.... That seems to hold stainsMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
There isn't a filler made that will take stain exactly the same as wood. Even different boards of the same wood species take stain differently.Political Correctness'.........defined
even if you countersink the screws 1/2 way down and use a dowel it will stain different. I've tried many different fillers from Elmer's to some stuff that cost $30 for a small can, all were about the same.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Just take a chain, a hammer, some gravel and other odds and ends, and, distress it. Then no need for filler
Stain the wood first then match the wood filler to the stained wood.
Not sure why you'd want to fill the screw holes. It'll be a beotch when/if you need to replace any boards... JMHO
Thats a great point....but too late!!
I tried hitting the filled spotts will drops of stain and let it sit a bit before brushing it in. Then went back and stained the entire board. It worked better but not great. I went overkill with filler and stain on the stairs since this area will take the brunt of traffic and the sun. Ill post pics tomorrow but I must get this done before the dog days of a SW Georgia summer. -
Key word on that can, PLASTIC.Political Correctness'.........defined
Mikey081057 wrote: »Just use pieces of old underwear.... That seems to hold stains
LOL. Best advice yet.
Three 20 amp circuits. -
Yesterday we had perfect weather and then it rain overnight. I’m moving on to the rest of the deck this morning and will go back to hit the lighter areas when it drys out here. That can of wood filler is getting returned.
I wouldn't use Gorilla glue on anything, terrible product.
Mixing saw dust with wood glue is pointless because in the end it's still glue without the grain or pores of real wood and therefore will take the stain differently.
There are ways to match the color and the appearance of grain in real wood, but it requires specialized materials and a lot of practice.Political Correctness'.........defined
Maybe in your world it looks ok, but in mine it looks like someone didn’t know what they were doing. No offense to you.
Gorilla glue is polyurethane based and requires moisture to cure. Because of that as it cures it foams creating air bubbles. Air bubbles in glue create a weak bond. Therefore, it is a terrible product.Political Correctness'.........defined
I wouldn't sniff no gorilla glue..My New Year's resolution is 3840 × 2160
Aren't you a deck wit!My New Year's resolution is 3840 × 2160
I think you have drank too much deck juice....My New Year's resolution is 3840 × 2160
You will find Liquid Wood right next to the black paint... I understand it can also be found in those stores that sell toys for bedroom use.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »PITA should be printed on the can of wood filler. I know someone who claimed there is a special filler to be stained over but I cant find it!
Amazon has all that, and more.
Gorrila glue is polyurethane based and requires moisture to cure. Because of that as it cures it foams creating air bubbles. Air bubbles in glue create a weak bond. Therefore, it is a terrible product.
Its a deck.
I mentioned the sawdust/glue as an option.
Glue is secondary, and again, a personal preference.
Bad advice is still bad advice and yours is bad advice.Political Correctness'.........defined
