speaker baffles
i'm new to the car audio. i bought some boom mate speaker baffles 6.5 and 6*9 they helped with the cheaper after marked speakers i had but i just upgraded to pioneers a series 6.5 and 6*9 and idk if i'm starving them for air should i keep using them or take them off. i have a 05 toyota corolla and the speakers are running 100 watt each
  • FestYboyFestYboy Posts: 2,326
    Most car speakers are designed to be in an IB configuration. Remove the baffles and deaden the panels. I can also guarantee you aren't using all 400 watts as you suggest.
  • littleasome14littleasome14 Posts: 8
    edited May 24
    FestYboy wrote: »
    true im using more or less because 400 watts is the rms on the amp its 800 watt maxs. also thanks ill cut the back of them at least the front i still need them my window seals aren't working well.
    Yeah, that's not how amps work... :| Most likely you're using a total of about 10-20w at even elevated listening levels.
  • mlistens03mlistens03 Posts: 1,000
    For me, even at the highest of listening levels, I rarely put out more than 5 Watts. (Based on calculations done judging by SPL, room size, etc.) My amp i should rated at 300, but it doesn’t only put out 300. It depends on the volume. I don’t know what the efficiency of your speakers are but assuming it is 90 dB/1w/1m then you would rarely use more than a watt.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • mlistens03 wrote: »
    okay and its 93dB 1w/1m for the 6*9 and 91dB 1w/1m for the 6.5
Howdy, Stranger!
