Personal Home Theater build, updated whenever
135
    VR3 Posts: 27,970
    thank you sir. It was kind of a last minute decision, looks cool but will add a lot of durability to a high traffic area of the house
  • cfrizz
    cfrizz Posts: 13,415
    Very, very nice!!!
  • mrbiron
    mrbiron Posts: 5,711
    Is that an adjustable lally column through your countertop?!
    Tony M Posts: 11,009
    Sure is. Sometimes you gotta do what ya gotta do. Right? ;)
  • verb
    verb Posts: 10,176
    Looking good! Love the waterfall on the granite? top. And the tile work! Well done!
    VR3 Posts: 27,970
    It is a temporary or permanent support post. It will be covered when everything is done, will look good
    Thanks guys!
    I knew it would. Can you get some strips of that countertop material to incase it?
    Backsplash strips maybe? I don't know... :|
    VR3 Posts: 27,970
    I'm thinking the bottom half and back side of cabinets on the living room side will be random rock, similar color to countertops and the top half maybe white casing so it blend in
    I like that idea a lot. B)
    VR3 Posts: 27,970
    Ady to start on the ceiling... Although that little cubby is going to be a pita to finish mudding
  • mrbiron
    You have to be nearing the 1/2 life of that drywall.
    Just use a 4” nap and forgo the mudding.
    Your wife couldn’t even pick matching curtains.....geesh.
    :D
    Was the section in the back of the alcove an after thought? You are absolutely right. That area will be a beach! Fortunately, it will be hidden behind what we can assume are electronics.
    As always Hurry Up!
    VR3 Posts: 27,970
    The alcove is procrastination at its finest lol
    The wife wanted the kitchen done first... What can I say
  • FestYboy
    FestYboy Posts: 3,861
    VR3 wrote: »
    What can I say
    Whatever she tells you...and no more.
  • HzTweaker
    HzTweaker Posts: 723
    That's a great Kitchen space! I love all the recessed lighting amongst everything else.
    2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    VR3 Posts: 27,970
    edited July 2018
    Thank you, @lightman1 spoiled me years ago
    VR3 Posts: 27,970
    Haven't quite made it to the sanding stage... But I'm very closeivarlx1t74sm.jpg
    VR3 Posts: 27,970
    Will be able to start priming this week, maybe paint this weekend... Will see! kaqp77y5iddo.jpg
    txcoastal1 Posts: 13,124
    That's gonna be sweet
    Bless the wife for putting up with the mess ;)
  • verb
    verb Posts: 10,176
    VR3 wrote: »
    Thanks man
    She went two years without a kitchen sink and cooked on a portable stove top, she's a keeper lol
    1 year for me! Gutted the kitchen over a year ago. I had to set up a little cooking area with a inductive hot plate, toaster oven, mini fridge, coffee maker, etc. Kitchen is fully functional now, just have to finish the crown moldings, baseboards, and other minor stuff. Did the under cabinet lights today!
    VR3 Posts: 27,970
    That's awesome man, it definitely takes time.
    Mine was a little involved as I did the living room at the same time...
    Over the past 4 years I did the following -
    Gutted kitchen and living room.
    Moved master bedroom door
    relocated laundry room
    added half bath (next project to complete)
    added coat closet
    built double closets for master
    added a pantry
    removed the corner that divided kitchen and living room and put the bar
    knocked down 5,000 pound chimney and added pop out for HT equipment
    New kitchen
    new living room
    Basically redid the floor plan a little, which was sorely needed
    VR3 Posts: 27,970
    Primed the entire room last night... Time willing will have the first coat for the ceiling tonight
  • joecoulson
    joecoulson Posts: 4,943
    Posting here so I can follow. I love a good HT build. Looks great
    VR3 Posts: 27,970
    Starting to get real, one more roll coat
  • WLDock
    WLDock Posts: 3,073
    VR3 wrote: »
    Thanks man
    Man, I'm year three in my house and purchased materials at the beginning. I still have some paint, floors, kitchen counters, and master bath to complete. The master bath has been out of commission for most of the time here. The plan is to finish it this weekend. Your journey is inspiring. Great work, and both our better half's are great for being patient. Well, mine has damn near cursed me out a couple of times....but , all great things will come in time.
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
    VR3 wrote: »
    Looking GREAT Trey! ;)
    What is the square hole in the floor of the recessed area for?
    pitdogg2 Posts: 24,481
    Tony M wrote: »
    VR3 wrote: »
    It appears to be for running wire
    VR3 Posts: 27,970
    Thanks guys
    Yes that is run wire, I'll make a Panel to cover it with a few thru plates but I wanted it removable
    EndersShadow Posts: 17,517
    VR3 wrote: »
    Thanks guys
    Just use these:
    VR3 Posts: 27,970
    I may use a floor box of sorts...
    Some of the wire is 3/4 inch thick
