My awful experience with Polk customer service.
  • anonymouseanonymouse Posts: 2,479
    VR3 wrote: »
    Where the crack in the circuit board, take a knife and gently scrape off the green coating over the copper.
    Take a wire, solder it to each side of the crack along each section where it is broke. Do this to any section that would otherwise be connected.
    Fixed, the end.
    What he said!
  • ManticoreManticore Posts: 286
    VR3 wrote: »
    Fixed, the end.
    So if you do this to fix a cracked board, does it matter if its solid or stranded wire??
    Denon AVR X4200W
    Parasound HCA 1500A amplifier
    Adcom GFA 555 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    NAD pp 4 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk RTiA 7's
    Polk CSi A6
    Polk RTiA 3's
    Polk SDA 1C's modded
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • FestYboyFestYboy Posts: 2,785
    Shouldn't matter, I've done both depending on where the repair is being done. Most times I'll flow a solid strand to help brace the board. In some cases, I've drilled the trace and placed the repair on the back side of the board if it made the repair easier to manage. Quality solder is the key here.
    FestYboy wrote: »
    Noted!! Thank You.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk RTiA 7's
    Polk CSi A6
    Polk RTiA 3's
    Infinity bu2 sub
  • Just wanted to update this! After going through my old emails I realized that I missed a email from Polk back in late march about parts being available now. Awesome news! I'm now pretty excited about the possibility of getting my speaker working so fingers crossed and I'll update this later!
  • leftwinger57leftwinger57 Posts: 2,883
    I haven't been around much but you did sound like that guy XCapri a lot. He's gone way long time now.
Howdy, Stranger!
