Polk Monitor 7 series 2
Are these true 8 ohm speakers or 6 ohm and what are the opinions on these?
  • mlistens03
    mlistens03 Posts: 2,767
    Monitor 7s are very well regarded around here, and I am wanting a pair myself (although I can’t really get one unfortunately). I believe they are 6 ohms, but you would have to wait for someone more knowledgeable about the monitor line to reply.
  • Cylontymany
    Cylontymany Posts: 42
    I already have the monitor 7 with peerless tweets but I am asking about the series 2
  • mlistens03
    edited May 2018
    The series 2 uses the sl2500 I think, but I don’t know what the impedance is, I would assume it averages around ~6 ohms, although like I said, I don’t know a ton about these speakers so you will have to wait for someone else more knowledgeable to tell you the impedance.
    F1nut Posts: 49,794
    edited May 2018
    Are these true 8 ohm speakers or 6 ohm?
    Why does it matter to you?
  • [Deleted User]
    @Cylontymany they are 8ohm speakers.
  • delkal
    delkal Posts: 764
    My opinion is the first model with the Peerless tweeters is MUCH nicer than the series 2. It would not be an upgrade.
    Polk claimed a lot of their early speakers were 8 ohm but many tested closer to 6 (and lower at certain frequencies). I don't think it makes any difference in the real world.
  • Cylontymany
    I was wondering about the series 2 because 8 ohm impedance is easier to drive than 6 or 4 ohms. But since the series 2 would not be an upgrade-what about sideways? Has anyone done any comparisons? I will never part with mine but was curious about the series 2
    mhardy6647 Posts: 33,029
    edited May 2018
    [emphasis added]
    The nominal impedance rating of a loudspeaker doesn't tell one much about how easy or hard it will be to drive. The impedance curve (along with phase) as a function of frequency will give some insight into how benign or (ahem) malignant of a load it might be :)
    Nice illustration (albeit hypothetical) from Eliot Sound Products (http://sound.whsites.net/patd.htm ) of a pretty typical impedance curve for a two-way loudspeaker with "typical" woofer and tweeter, and a second order crossover feeding each driver (with a Zobel network This also shows the nature of the load (as "seen" by the power amplifier) as a function of frequency (impedance).
    This is what the phase behavior of that simulated simple two-way speaker would look like.
    This would probably be a nominally 4 or 6 ohm speaker -- based on the impedance in the 200 to 400 Hz region... but you can probably tell even from this simulation of a fairly ordinary speaker that one number doesn't tell much.
    I've never knowingly heard a "series 2", so I can't help with your questions.
    Hard to imagine that they'd better the originals -- which were, and are, pretty darned good sounding little monkey coffins.
    EDIT: PS It's stuff like the complexity of the speaker "load" as it is "seen" (or "felt", if one prefers) by an amplifier that goes a long way towards illustrating (I think!) why there is such a thing as amplifier/loudspeaker "synergy" :)
  • Cylontymany
    I saw a discussion over at Audiokarma about the Monitor 7 series 2 that is an 8 ohm speaker which sparked my interest. How good are they compared to my original peerless ones is what I am trying to find out.
  • mlistens03
    Peerless tweeters are better, the later tweeters (sl1000, sl2000, sl2500, sl3000, etc.) all had a spike in the treble between around 12-13 kilohertz I believe. Polk actually made the new RD0 line of tweeters as drop in replacements for the sl tweeters mentioned above. Customer service at its finest
    I definitely prefer the Peerless tweeter, FWIW.
    I have minimal ears-on experience with the modern replacement/upgrade tweeters for the later series, so I don't have much to offer on that front, I'm afraid.
  • westmassguy
    westmassguy Posts: 6,850
    mlistens03 wrote: »
    Partially correct. The SL1000, SL2000 had the resonance spike. The SL3000 Tri-Laminate did not, nor did it's more cost-effective sibling the SL2500. The RD0194-1 is a direct, drop-in replacement for the SL2000, however some creative modifications must be made when replacing the SL1000. The RD0198-1 is a drop-in for the SL2500 and SL3000.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • mlistens03
    mlistens03 wrote: »
    Wait, so what was wrong with the 2500/3000? You have me officially intrigued .
    pitdogg2 Posts: 24,556
    edited May 2018
    mlistens03 wrote: »
    mlistens03 wrote: »
    RDO 198 is a better smoother tweeter. The 2500/3000 can still be very harsh at some frequencies. The metallized vapor deposited domes are still polyamide underneath AFAIK.
    198 is more of a silk dome type of tweeter.
