Marantz SR5012 with Polkaudio RTI A9
Good morning. I kindly need a suggestion. I'm going to buy a power amplifier Marantz SR5012 and a couple of Polk Audio RTI A9. I need to know if the Marantz SR5012 is technically compatible with the RTI A9 and if its power is suitable to move such a big floorstanding speakers.
The best practice is to listen an hi fi system before buy it, but in my case it's impossible. In Italy, at this time, there aren't hi fi store with the brand Polk Audio.
For this reason, I ask you if you ever tested this power amplifier with the RTI A9. If yes, the system sounds good? If no, do you think that, referring to you experience in audio systems, SR5012 + RTI A9 will be a good choice? Thank you, kind regards.
  • dolbyddolbyd Posts: 262
    edited May 14
    You will need a high current amplifier with the 9s.
    The Marantz is a great receiver and has pre amp outputs for all channels of amplification.
    If you go with a 2 channel amp you can use the receiver for the rest of your speakers.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 7704, OPPO 203, Emotiva XPA-5 Gen2, Emotiva X-500,X-150, Sony 75" 940E, Panasonic Plasma VT50,PS Audio Power Port X2, Perfect Wave AC-5 x4
    Office- Infinity Kappa 600, Kappa Center, in ceiling Polk RC80i, SVS PC 2000, Marantz 5010, OPPO 203, Emotiva X300, Sony 48"
    Master BR- LSi7, LSiC, LSI700 in ceiling, SVS-PC 2000, Marantz SR5012, Adcom 7500, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" 800B
    Workout room- RT2000P, CS1000P, Pioneer Elite SC81, OPPO 103, Panasonic Plasma VT 42"
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    Storage room at this time- LS90, RT16, CS350LS
  • MaurillioMaurillio Posts: 2
    Thank you dolbyd for answer.
    The Marantz SR5012 is a 7.2 system.
    Will a solution be, that I bi-amp the RtiA9 using the surround ports of the amplifier?
    The room in which the system will play is small (23ft x 16ft). The purpose is to have a
    system that sounds at low volumes clearly and reproducing all the frequency of
    music.
    Referring to what I have written, do you suggest to proceed with be-amplification or is better than I choose a smaller system, both speakers and amplifier?
    Thank you, best regards
  • mlistens03mlistens03 Posts: 1,405
    Maurillio wrote: »
    music.
    If I was you I would get the Marantz and the speakers, then get a used (or new) separate pre amp. Used I would look at used Parasound/B&K/NAD (anyone else have suggestions? I know there are more but I can’t think right now), new I would look at the same brands or for budget Emotiva or if you have a REALLY low budget, a Crown or similar PA amp (although I would suggest going used instead).
    If this is for music then I would not suggest the RTiA series, as they are great for movies but are terrible for music (they have really harsh highs that are extremely fatiguing). I would go with the LSiM or Signature series, or if you want to buy used you can get a pair of LSi series speakers (although with the LSis you will need a beefy amp, they are hard to drive).
    We are here for more help if you need it.
    Micah
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
  • LegenderLegender Posts: 450
    The AVR is fine for the rest of the speakers, but you're going to need high current to drive the 9s. The AVR should have preouts ( I haven't looked) but should support an amp inserted between the AVR and the speakers. Don't bother with the bi-amp on the AVR to your speakers. Won't help near as much as a separate amp.
    At another location I'm driving some RTiA7s with an older Sherwood 5 channel amp and really helps to deliver a better sound. Few hundred bucks and really helps the sound. Actually helps them sound better with music also.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
Howdy, Stranger!
