Silver, silver clad copper etc.
I think I cured my 707's with Ben's silver IC's and BJC silver clad IC's but maybe it's just the DAC? Does anyone use the above, not necessarily the brand but if so what has silver done for you?
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • F1nutF1nut Posts: 39,604
    It made me a rich man.
  • afterburntafterburnt Posts: 4,388
    edited March 11
    Jesse, I had 1000 ounces of that carp in the late 80's? held it for years and it did nothing! Funny the theory was that it was better than gold because it was consumed in photo processing lol!
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Just messing around Bruce.
    Tried some silver Nordost speaker cables once, which were awful and put me off of silver cables for years. Over a year ago I bought some silver umbilical cords from Revelation Audio Labs for a separate power supply, which turned into one of those wow experiences. I know Bluefox loves them too.
  • fbm211fbm211 Posts: 1,455
    Revelation audio labs makes some great cables. I have ICs ,an AES/EBU and i2s cables. DH labs makes some good stuff too.
    SDA-2BTL with custom IC
    Theta Data Basic Transport--Camelot Arthur DAC--Camelot Dragon Pro2 MK III
    Harman Kardon T-55c TT
    Prophecy Cryo-Silver Reference AES/EBU
    Prophecy Cryo-Silver i2s digital cable
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • tonybtonyb Posts: 29,042
    afterburnt wrote: »
    I've used Ben's silver before, a bit harsh on the top end. There is more to a cable than just the metal used. Silver can be harsh or warm, depending. Same with copper. Usually the cheaper cables that use silver, will souned more detailed but a tad harsh, and they lose some tone to the notes that copper excels at. Just my .02
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    Ny 707's are no longer "meh" :#
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • MrBuhlMrBuhl Posts: 2,273
    FWIW - I have found the Signal Cable Silver IC's to be very nice, and I especially like them combined with Toobs - maybe they detail up a little of that softness, I'm not sure I could exactly say why, but it's a tasty match IMO.
    VA 2 Channel ,Dodd 50W Dual Mono EL34 Amp, MFA based Cocci Tube Preamp, Polk SDA2BTL (fully modded), A/L 1000VA Dreadnought, Canare 4s11 SDA cable, Sony S9000ES CD/DVD/SACD, Music Hall mmf 5.1 Turntable, Vincent Pho-700 Phono Pre, MIT S3 IC's / MIT Shotgun S3 Speaker Cables / Pangea & Signal Cable MP power
    LA Pass Labs X150.5 Amp, Eastern Electric MiniMax Preamp, Polk LSIM705, Marantz DV8300 SACD, Audioengine B1, MIT AVt3 Speaker & RCA Cables, PS Audio Power Punch power cables
    Dodd Mid Level Preamp ("on the bench" w/Charlie)
    Polk SDA1c modded
    Soundcraftsmen PCR800
    Yamaha YP-D6
    Audible Illusions L1 Preamp
    McCormack DNA-1 Power Drive Amp
    Eastern Electric Minimax CDP
    Infinity RS5b Speakers
  • DarqueKnightDarqueKnight Posts: 6,193
    afterburnt wrote: »
    Silver has left a gaping hole in my wallet.
    In my two channel rig, the interconnects and speaker cables are AudioQuest Sky Gen. 2 solid silver. The power supply umbilicals in my Pass preamp are Revelation Audio Labs solid silver.
    In my office rig, the interconnects are PS Audio xStream Transcendent XLR solid silver. The preamp power supply umbilical is Revelation Audio Labs solid silver. Power cords are PS Audio Premier SC solid silver.
    In my home theater rig, I have Signal Cable Silver Resolution Reference hybrid silver/copper interconnects.
    I don't have a particular preference for silver wire. It just turned out in some cases that the cables I liked the best happened to be made of silver. PS Audio's former top power cord, the Premier SC ($1,793 for 2m length), had solid silver conductors. They later introduced two higher performing, and lower cost power cables that had copper conductors: the AC10 ($850 for 2 meter length) and the AC12 ($1,200 for 2m length) . The higher performance of the AC series cables was achieved using better conductor geometry, very high quality copper, and very high quality insulation and construction techniques.
    You may find the thread below interesting:
    http://forum.polkaudio.com/discussion/56978/silver-cable-economics
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
  • Joey_VJoey_V Posts: 6,519
    I don't like silver plated, but I use AQ WEL which are full silver speaker wire and full silver power cords. I find them to be excellent.
    Joey's Gear:
    Current Gear:
    Torus RM15 -> Emm Labs DAC2x and TSDX Transport -> Cary SLP-05 preamp -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
    Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
    Old Gear:
    Speakers: BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source: Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification: Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased)
    Amplification: HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer: Infinity Entra2 sub -> SVS 25-31PC+ sub
Howdy, Stranger!
