Should I connect my TV to my DAC?
I watch a lot of music documentaries and I am wondering should I run an optical cable so I can listen through my Ushers or is this against the law?
    Clipdat Posts: 12,526
    Do you own an optical cable?
    tonyb Posts: 32,901
    You can...wouldn't hurt.
  • afterburnt
    afterburnt Posts: 7,892
    Clipdat wrote: »
    Yeah, it's sitting by the TV looking at me.
  • rooftop59
    rooftop59 Posts: 7,937
    Obviously the quality of the digital circuitry in the tv is the limiting factor here, but it will still sound better absolutely. what is the source? A built in app on your tv? If that’s the case then a Roku or some other dedicated streaming device would be a better so Bri g optIon, and yuh can get one for like 50 bones if u look around...
    Game Room 5.1.4:
    Bedroom 2.1
    Viking64 Posts: 6,630
    Be careful. Sometimes sending light through one of them there op-tickle cables opens a wormhole to another dimension. You don't want to slip into the abyss of a hell where Bon Jovi is the frontman for Led Zeppelin.
  • afterburnt
    @rooftop59 its the Amazon app on the TV. I have a Fire Stick that I never use, why is that better?
  • Hermitism
    Hermitism Posts: 4,190
    I watched Jon Bon Jovi on the Rock & Roll Hall of Fame this weekend and I'm 99% sure he completely plucks all of his eyebrows off and then draws them on. I did enjoy his speech though. Just thought I'd share that random tidbit.
    edited May 2018
    Hermitism wrote: »
    Yeah, he has really let himself go. :p
  • Hermitism
    I found his lack of eyebrows completely distracting.
  • rooftop59
    afterburnt wrote: »
    Well, that won’t be better because it’s only hdmi and you need optical coax or usb I’m assuming. You would need dedicated streaming box with optical out like the Roku ultra or an older amazon fire tv. Those are optimized for streaming, they might give you a slightly better audio signal, but probably not by much honestly.
    Hook it up to the tv and let er rip!
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    @rooftop59 ok I got ya, I wasn't thinking boxes all I got is sticks. My Roku stick is out of town now.
    I was concerned about insulting my Ushers.
    Kinda like that guilty feeling you get when you play a porno video through a $1k DAC?
    afterburnt wrote: »
    pitdogg2 Posts: 24,420
    Clipdat wrote: »
    afterburnt wrote: »
    Do you get smellavision?
  • afterburnt
    Hmmm, this cable is screaming with no signal going to it, what does it all mean Basil?
  • Joey_V
    Joey_V Posts: 8,492
    That’s what I do
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • afterburnt
  • afterburnt
    anyone ever had their optical cable scream and cry for no apparent reason?
    txcoastal1 Posts: 13,119
    Explain
  • afterburnt
    Plug it into the TV saw light at the other end. Plugged it into the DAC and it makes a God awful growl before switching the TV output to optical.
    Growl coming from the speakers when you do this??
  • afterburnt
    edited May 2018
    Correct, from the Ushers
    But normal once it's switched??
  • afterburnt
    No It just howls all the time
    Have you tried another optical source
    afterburnt wrote: »
    anyone ever had their optical cable scream and cry?
    That your little world won't let you go?
  • afterburnt
    txcoastal1 wrote: »
    Duh, I could put it on the HT to test it. I was just stuck on "the other optical cable I have it too short" thanks Ron. I can't think my way out of a paper bag! I almost died like that a couple of times. :#
  • afterburnt
    Looks like it's the new TV! :s
  • warren
    warren Posts: 756
    Got HDMI?
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • warren
    warren Posts: 756
    How did you ever hook up all this great gear? Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Some final words,
    Warren
