Proper orientation of male split pin RCA plug
13»
  • afterburntafterburnt Posts: 4,425
    mlistens03 wrote: »
    mlistens03 wrote: »
    Hey, I need your help, I can't figure out how to ignore @viking64. :wink: :tongue:
    Congrats, you just joined the class clown and clipdik on my list. Shame, I thought you might turn out ok.....oh well.
    Apparently I’ve been ignored. I’m not quite sure what I did. Can someone enlighten me?
    I would tell you but I am pretending to ignore you.
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • msgmsg Posts: 4,196
  • verbverb Posts: 2,732
    Clipdat wrote: »
    Wondering if someone can help shed some light on the proper orientation of a male RCA plug with a split pin, in regards to how to correctly insert it into a female RCA jack.
    I notice that with the split pin cables, that when I'm plugging them in and they rotate slightly, sometimes I can hear and feel what I'm guessing is the metal inside getting stuck on the split of the pin slightly. It makes a little twang sound, like it stuck for a second and then releases.
    Looking inside a female RCA jack, there appears to be a horizontal piece of metal. I'm guessing this is what makes contact with the male pin and transfers the signal.
    Now, in regards to the split pin, how should this be plugged in to make "proper" contact? If I plug it in so that the split is sitting exactly horizontal, then the horizontal metal inside the jack will actually get inserted inbetween the split tip! I can't imagine that is ideal..??
    If anyone has a diagram of what the inside of a female RCA jack looks like, maybe that would help. Or any insights from people who having experience using RCA interconnects with split pins. Thanks.
    The below image may help explain the issue you're having. The center contact is simply a "spear" that is designed to engage the pin of the male connector, then deflect slightly during insertion while still maintaining contact.
    Should be not an issue with a solid pin connector. Nice smooth rounded end.
    However with a split pin, you have a cut right down the middle of the pin, introducing essentially a "slot" with two sharp edges. Not smooth by any means. Not hard to imagine an orientation of the slot engaging the end of the spear! At that point, the spear may actually be partially engaged in the slot, and with a little twist you bend the spear out of the way, once out of the way, twang!, the spear comes back to it's normal position.
    Just a theory of course, would have to be verified via experimentation. FWIW.
    Basement: Polk SDA 1C's, Micro Seiki MB14 TT, Rotel 1580 Pre, Marantz CD6006 CDP, Carver TX8 Tuner, Conrad Johnson MF2300A Amp, Furman 15PFi Power Conditioner, AQ Diamondback (version 1) RCA IC's, MIT Terminator2 Cables
    Office: PC, Marantz AMP-1, Acoustic Technologies Classic Speakers, Polk PSWi225 wireless sub, MIT AVt2 cables, IFI Purifier2, AQ Cinnamon USB cable
    Spare Room: Dayens Ampino Integrated, Auris BluMe, Polk TSi200's
    Living Room: Pioneer SX-N30 Network Receiver, Pioneer PD10AE CD Player, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi Subwoofer
  • ClipdatClipdat Posts: 4,209
    edited May 1
    Nice explanation, that's exactly what's occurring! Now I know why you get paid the big bucks!
    You can see the "U-shaped" piece of metal that I was trying to describe on the left hand female RCA jack above. Both the sides and the end of it are what can get caught in the split tip.
    So, it seems like the split tip cables would work best for higher quality RCA jacks that feature a full 360 degree cup for the tip to sit in, versus the cheaper/more common style that are on most gear.
    At this point the split tip seems like a bit of a marketing gimmick, imo.
    Got Dayens?
  • mlistens03mlistens03 Posts: 1,405
    edited May 1
    Is there a supposed reason for the split tip? I've only ever seen it and I thought it was some way to make the cables cheaper.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    I'm not an expert, but I believe they're designed to mate with a better quality RCA jack (cylindrical IIRC) instead of the spear type. The spear type is about as inexpensive as it gets.
    The split types are designed to deflect themselves (spring loaded) upon insertion, to ensure good contact along the entire mating surfaces, and keep good retention.
    Here's some marketing gibberish I've found just now regarding split pins:
    Split Pin Technology Ensures a Secure Connection.
    split-tipped center pin to ensure a tight connection and flawless signal transfer.
    the split pin and collar gold-plated RCA's also maintain a robust signal path and longevity.
    Split center pin allows for superior signal transfer
    split tip center pin and segmented shield for maximum contact and reliability
    Got Dayens?
    verb wrote: »
    Clipdat wrote: »
    nice idea, but it doesn't seem like a winner to me... basically, your paying more money for less material?
    nbrowser wrote: »
    Marketing lies at its best....
    definitely.
    2 channel
    Pc gaming setup
    txcoastal1 wrote: »
  • tonybtonyb Posts: 29,305
    nbrowser wrote: »
    Marketing BS at its best....
    Indeed....same people who wrote that probably also write for womens magazines. ;)
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    Clipdat wrote: »
    However the issue/situation here is that for a cable that has some weight/body to it, when you plug one end in, and then attempt to run it to the other piece of gear you are connecting, the weight and bulk of the cable can actually inadvertently rotate the plug in the jack.
    How about....resting the plug inside the jack without inserting all the way, then when the other end is connected, and the weight of the cable settles....you push it in. That way no additional turning happens.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • pitdogg2pitdogg2 Posts: 10,217
    tonyb wrote: »
    Clipdat wrote: »
    Know it all!!!
  • machonemachone Posts: 971
    I think I need to go lay down........
    Mojo Audio Joule v5>>Quantum Byte w/JRiver 21 and Fidelizer>> Starlight 7 USB >> Marantz SA 8005>> Equinox 7>>
    ModWright SWL 9.0 SE Signature >>Equinox 7>>
    Hafler DH-500 Amp+ (Musical Concepts PA-6 Elite Mod) >>Belden 5000 10 ga cables>>
    SRS 2.3TL (Fully Modified)...SDA-1A (Fully Modified with Dimensional Tweeter Delete)
    1KVA Dreadnought
13»
Howdy, Stranger!
