Need a PSW-150 base
Just got a PSW-150 without a base. Does anyone have either a base or the actual sub that they are willing to part with? If you have one that doesn’t work anymore for example. I’ll take it off your hands.
  • verb
    verb Posts: 10,176
    I don't have the base, but I have a cone from an RT-800 salvage, IIRC. Yours if you want it. The remainder could be fabricated easy enough. Let me know!
  • honestaquarian
    honestaquarian Posts: 3,186
    verb wrote: »
    I am assuming you mean the power port cone? Is it the same size?
    What do you mean about the remainder being easy enough to fabricate?
  • verb
    verb Posts: 10,176
    Not sure about the same size, but it should work, IMO. The base and standoffs could be fabricated out of materials readily available from a home depot or lowes IMO. MDF, or solid wood for the base, and round dowel stock. For reference:
  • honestaquarian
    Hey is that pic recent from us audio mart?
  • verb
    verb Posts: 10,176
    Yup. It popped up when I did a search.
  • honestaquarian
    I can't find it there
  • verb
    verb Posts: 10,176
    Sorry I didn't clarify. I did a google search on Polk PSW150. Lots of images out there.
  • quickr1
    quickr1 Posts: 414
    I have the whole unit.
  • honestaquarian
    @quickr1 is the sub functioning? Do you have pics?
  • quickr1
    quickr1 Posts: 414
    Last time it was hooked up(years ago), I believe it had a scratchy sound to it. Pm me an email and I can send you some pics if you like.
  • honestaquarian
    quickr1 wrote: »
    @quickr1 Did you get the PM I sent you?
  • quickr1
    quickr1 Posts: 414
    Yeah. Sorry busy day yesterday. I will get some pics after work today and send them to you.
