Need a PSW-150 base
honestaquarian
Just got a PSW-150 without a base. Does anyone have either a base or the actual sub that they are willing to part with? If you have one that doesn’t work anymore for example. I’ll take it off your hands.
I don't have the base, but I have a cone from an RT-800 salvage, IIRC. Yours if you want it. The remainder could be fabricated easy enough. Let me know!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I am assuming you mean the power port cone? Is it the same size?
What do you mean about the remainder being easy enough to fabricate?
Thanks -
Not sure about the same size, but it should work, IMO. The base and standoffs could be fabricated out of materials readily available from a home depot or lowes IMO. MDF, or solid wood for the base, and round dowel stock. For reference:
Hey is that pic recent from us audio mart?
Yup. It popped up when I did a search.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I can't find it there
Sorry I didn't clarify. I did a google search on Polk PSW150. Lots of images out there.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I have the whole unit.
@quickr1 is the sub functioning? Do you have pics?
Last time it was hooked up(years ago), I believe it had a scratchy sound to it. Pm me an email and I can send you some pics if you like.
@quickr1 Did you get the PM I sent you? -
Yeah. Sorry busy day yesterday. I will get some pics after work today and send them to you.
