Post a picture... any picture
12092102122142151073
    txcoastal1 Posts: 13,124
    nbrowser wrote: »
    CH46E wrote: »
    nbrowser wrote: »
    CH46E wrote: »
    mrbiron wrote: »
    CH46E wrote: »
    A litte of just about ever illicit drug. One day all going out on a "Rave Cruise"
    Party p00per....
    Actually i was mistaking. This was the left overs of what was comming back into the US after the rave cruise. We had a LOT more on the day they boarded. 27 arrests iirc. 3 went federal.
    Oh my...you CBP?
    Yes, so you are Canadian i take it? Bassically a US Cit... lol. Not to many people know what CBP is.
    LOL I can drive right down a road in Surrey, Langley and Abbotsford BC called 0 Avenue. If your heading say westbound...the stuff on the other side of the ditch to your left is American soil. I can see some CBP vehicles on the other side once in a while, Granted they probably have an easier job up here than they do on the southern border. In the following photo you can see the flags, each is in it's correct country. This is the Smugglers Inn in Blaine Washington, the photo was taken from Surrey British Columbia. The small boulders denote the 49th parallel.
    So why don't you order US gear and have it delivered to the Inn for pickup ;)
  • CH46E
    CH46E Posts: 3,521
    nbrowser wrote: »
    txcoastal1 wrote: »
    nbrowser wrote: »
    CH46E wrote: »
    nbrowser wrote: »
    CH46E wrote: »
    mrbiron wrote: »
    CH46E wrote: »
    Party p00per....
    Oh my...you CBP?
    Cameras and sensors monitored by both the CBSA (Canadian Border and Security Agency) and the 'Murican CPB. You walk across there and your in trouble no matter what direction your headed. At one point not long ago (few years actually) people would get a room there then at night, walk into Canada thinking they were undetected...NOT! There is a offical border crossing less than 2Km to the west of that place. That said, I don't have a passport and have zero interest in entering the United States until a few things change down there.
    For sure you dont want a "ewi" (entered without inspection) on your record. It will cause you years of crief when crossing any US border.
    Tony M Posts: 11,009
    edited May 2018
    I bought a pressure washer spinning head basket from Lowes AFTER a lot of research.
    Best 100.00 I ever spent to ease our laboring pains cleaning our driveway. It usually takes about 10 hours over two days time. Multiple tanks of gas too.
    Today, 3 1/2 hours and I almost did it all! 2 tanks of gas and I just filled the third and used it for 15 min. Probably 3/4 of a tank left. Incredible. Hardly any effort to push, pull or go side to side. It just about floats around where you want it to go.
    You can read the reviews here if you're in need of a pressure washing tool for your driveways and side walks. I'm glad I bought a 2'extention wand( I think it is) thinking I'd want a longer rod.
    https://www.lowes.com/pd/SIMPSON-Universal-Spray-Wand-for-Cold-Water-Pressure-Washers/999992128?cm_mmc=SCE_BINGPLA_ONLY-_-SeasonalOutdoorLiving-_-SosPressureWashers-_-999992128:SIMPSON&CAWELAID=&kpid=999992128&CAGPSPN=pla{ifdyn:dyn}&k_clickID=019d7f06-f453-4ec9-879c-f5adb799ae4e&msclkid=7f2265e0c926135bd8d43f11d09c6a2c
    But my nozzle wouldn't come off the the original pole so I could ad it. BUT, it worked out great anyway. I just switched back and forth between the spray wand and nozzle to the spinner basket and new wand. You have to sray off the drive AFTER using the spinner but it was SOOO easy to switch! I actually had FUN!
    https://www.lowes.com/pd/SurfaceMaxx-Pro-Pro-PW-Surface-Cleaner-4500-PSI/1000382309
    cleaned the shite out of your shoes too :D
    edited May 2018
    The basket lifted up once and I've got to say, those warning all over the top of the basket are for real! :o:#
    I don't think it will cut material but if those nozzles get up to your socks or legs.. :s ..emergency room will be needed quickly. Seriously :#
    I was impressed at its efficiency. But it doesn't leave a clean path behind it. It leaves a clean surface with the loosened dirt and whatever back onto the surface. But you can tell where you've washed pretty easily! :)B)
  • FestYboy
    FestYboy Posts: 3,861
    nbrowser wrote: »
    Ah!!! Northstar!!! Run away!! :#
  • FestYboy
    ^ add some mechanics wire, and I think you're on to something.
    Clipdat Posts: 12,559
    Very cool and impressive! Wow.
    lol. I didn't see the tuckered out dog at first, just the stone wall. I just thought wow yeah those look like pretty big stones.
    Then I scrolled down and saw the tired pup and laughed. Looks like he/she got tired just from watching you work! :)
    audioluvr Posts: 5,420
    Crater lake in the spring
  • FestYboy
  • CGTIII
    CGTIII Posts: 1,022
    My Freddy pal. Passed in 2005.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    nbrowser wrote: »
    I don't think this will work too well...
    With this fix, you get the "30 seconds or 30 ft. guarantee". :D
    mhardy6647 Posts: 32,926
    good to the first bump
  • Mikey081057
    Mikey081057 Posts: 7,127
    Garage | Polk Monitor 5B's
    That's not dinner
    Give up your TX TDL....
    txcoastal1 wrote: »
    That's not dinner
    I actually had Rudy’s BBQ for lunch today! Our department had our annual outing to a baseball game. This year it was a suite at the Frisco Rough Riders game.
    Then you can keep your card, daily balance is needed in TX ;)
    edited May 2018
    I tried to teach my step-daughter EVERTHING about a car when she got her "learners permit". I spent a lot of time on backing up skills. Maybe too much because she ALWAYS backs into parking spaces. 20 years she's been doing that! :D
    One of my favorite pranks B)>:)
  • lightman1
    lightman1 Posts: 10,776
    Open tin of sardines on the exhaust manifold
    edited May 2018
    Anybody do the hand slapping on a door panel and seat while sitting in the passenger seat to freak a driver out?
    Flat tire? Oh no!
    Baggie of limberger tucked under the seat during the summer
