Polk Audio LSiC center speaker
PA1888
Hi, I'm looking for some advice please, I purchased a LSiC center speaker off eBay and when I was listening to the speaker I noticed the left side 5 1/4" driver was putting out very minimal sound compared to the right. When I talked to the seller he was trying to tell me that the left side is suppose to be this way and was told that by a Polk Audio specialist a few years ago.
When I contacted a Polk audio specialist yesterday, and he told me the sound should be equal out of both drivers. This is my feelings all along, what do you guys think?
I don't know for sure, but I do know that on the older cs400i, one of the drivers is full range, while the other is a midrange driver, so one does sound a bit louder/different from the other. But I don't it should be drastic. Have tested it with a variety of sources?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Yes, I also took out each speaker and switched side with both and it was still the same. So if there is a problem it isn't the speakers but I was thinking it was the cross over inside. But the sound difference is pretty drastic compared to each other.
There's nothing wrong with your speaker, that's how it's designed. It has a cascaded crossover designed to prevent frequency cancellations from having two drivers side-by-side with overlapping dispersion patterns.
Thank you very much
You're welcome, enjoy!
Just tried with our LsiC, and with some voices lacking bass the one speaker is nearly silent, as intended.
Thanks for your reply....it just freaked me out, and i thought maybe I had a bad crossover
