Signa S1 not working
I hooked up this sound bar and it works fine on the TV but when i switch to watch a blue ray i get no sound. I have used the small cable hooked directly to the TV and my Blue-ray player is hooked up to the TV with HDMI cable. Let me know if there is something that i can do to make this work.
Thank you
    EndersShadow Posts: 17,517
    What format are you sending out on the blu-ray player? It could be that you need to adjust the setting on it to send the audio out over HDMI differently. It also could be a audio setting in the TV that you need to adjust to make sure its passing the signal right as well.
