RTIa9 with Marantz PM6006
Is this Marantz PM6006 enough to power my RTia9 speakers in stereo mode? I will only using them for stereo.
  • gp4jesusgp4jesus Posts: 1,155
    edited April 30
    Not likely unless you watch the volume in a small room. No parties or bass-heavy program either.
    The ‘A9s love power. I suggest:
    a. Rotel 900 series (990*, 980/981) or
    b. Parasound 1200*/1500* or 1000A**.
    Either* or one per channel*** 980/981 or 1000A
    * best choice in that series/brand
    ** 120WPC & more peak current versus the 1000 - 110 WPC
    *** I’ll get a few tomatoes for this one.
    Ears!
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
  • tonybtonyb Posts: 29,305
    Will you get sound ? Sure....but you'll risk doing damage to the speakers, receiver, or both without powering them properly. Find yourself a used amp for around 4-500 bucks, preferably a Parasound HCA 1200-1500, B&K amps, Those are about the cheapest options and would match up well with those speakers.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
    What tonyb said too!
  • rooftop59rooftop59 Posts: 4,307
    Robissimo wrote: »
    The ironic thing here is that you would be better off using them with less power in a 5.1 setup, because in that scenario most of the audio goes to the center and sub*. IN pure two channel, those 9s are getting everything, and blown tweeters in your future we see.
    *I'm NOT saying that's good idea, just that you are assuming you are kay since you are just runngin them stereo, and the fact is that if anything you are worse off in this case. **
    **I just wanted to get in on the trending use of asterisks today! #@mhardy6647the trendsetter
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
  • mdaudioguymdaudioguy Posts: 4,481
    Y'all need to make some better recommendations! The PM6006 is an integrated amp. Suggesting straight power amps means he also needs a preamp.
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
Howdy, Stranger!
