What FM antenna/s has/have worked for you?
Tony M
Tony M Posts: 11,017
edited April 2018 in The Clubhouse
I've had success with these Terks. I've also liked and still use the ol rabbit ears and plastic tee ones.
https://www.ebay.com/itm/TERK-POWERED-AM-FM-AMPLIFIED-SIGNAL-ANTENNA-PI-B-INDOOR-HDTV-HOME-OFFICE-TV-USED/183186938649?epid=1600044590&hash=item2aa6cadb19:g:oTkAAOSwtfhYtKCh
And this one is awesome; The white fuzz is not on the original picture! That corrugated back plate folds down and there are two dials on the right side to help with dialing in the stongest signal.
http://www.terk.com/radio-antennas/?sku=AF1
«13
    pitdogg2 Posts: 24,579
    edited April 2018
    outdoor is best hands down. winegard if still made..
    mhardy6647 Posts: 33,046
    Yes an FM Yagi with plenty of altitude and a rotator -- but good ones are harder & harder to find. I bought a little FM directional from MCM some while back (before they got sucked up by Newark) -- haven't put it up yet, though.
    Meanwhile, I am using this little guy to listen to the one station we usually listen to.
    14015969136_4b20b7732a_b.jpgDSC_9169 by Mark Hardy, on Flickr
    What do you do to prevent lightning strikes from entering what's hooked up to them?
  • verb
    verb Posts: 10,176
    My subdivision doesn't allow external aerial type antennas. Yeah I know. Association Boards. Agree with Dogg, Winegard 6065 is highly touted. I too am am in search of a killer indoor antenna.
    Winegard 6065:
  • verb
    verb Posts: 10,176
    On eBay right now:
    https://www.ebay.com/itm/TECHNICS-16-5-FM-WING-ANTENNA-SH-F101-VINTAGE-MADE-IN-JAPAN/292404065121?epid=559615231&hash=item4414a3f361:g:pbIAAOSwKwVaVxhA
  • Mikey081057
    Mikey081057 Posts: 7,127
    I get every station in the galaxy
    Garage | Polk Monitor 5B's
  • motorstereo
    motorstereo Posts: 2,052
    edited April 2018
    Outdoors and up high hasn't failed me yet. I even had good luck doing this in the past with a simple dipole spread out on a stick and placed up high.
    verb wrote: »
    On eBay right now:
    Mine was $7.
    I wouldn't recommend one for $135 :/
  • verb
    verb Posts: 10,176
    I figured as much! :smile:
    gudnoyez Posts: 8,066
    I've got a couple of terks that work quite well. This one from Audio Advisor looks like a good one for the price. I need one for a receiver in the garage and this might be worth a try.
    http://www.audioadvisor.com/mobile/prodinfo.asp?number=GDFM1A
    Tony M wrote: »
    Lightning arresters at the grounding block.
    You could also drive a 12' ground rod in the ground with 6ga solid copper.
    My antenna tower is 35' tall with a deep fringe channel master OTA antenna good to 80 miles for FM and much further on great days.
    Not once in 30 yrs have i had a strike but there are was to minimize problems.
    verb wrote: »
    Winegard 6065:
    Is it still available? I looked on Winegard's site and only see a 'turnstile' type omni.
    There do seem to be a couple of serious FM Yagis (or log periodics) on Google -- but I know nothing about most of the ones I saw, like this one (that I found looking for the Winegard):
    http://dennysantennaservice.com/long-range-fm-antenna.html
    Winegards are no longer made but others are out there.
  • Mikey081057
    I used to use an antennae but can find any station I want on the internet.
    Clipdat Posts: 12,607
    Great job at missing the entire reason for this thread and making a pointless post.
  • verb
    verb Posts: 10,176
    verb wrote: »
    Winegard 6065:
    Naw, discontinued. There was a NOS on eBay that recently sold. I did see the Denny antenna too, looks like a close facsimile.
  • verb
    verb Posts: 10,176
    This one seems promising. Winegard HD-6010. Small enough to be attic mounted. Less than 50 bucks.
  • FestYboy
    FestYboy Posts: 3,861
    One could always make their own... Not difficult and you can tailor the length to pull in the frequency you want more effectively than the mass built units. Most single pole or loop antennas are built to sit dead in the center of the FCC allocated bandwidth... Not so good if the station you want is on either side of that spectrum.
  • Msabot1
    Msabot1 Posts: 2,098
    Uhhhhh...you just might be getting a strongly worded letter from the homeowners association for that one...LOL!..
  • machone
    machone Posts: 1,475
    verb wrote: »
    Got one of these on my attic. Works good.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    edited April 2018
    A quick read of the Denny's page suggests it is a repurposed TV Yagi -- the FM band, as youse guyses likely know, lies between the old analog TV channels 6 and 7 in the VHF spectrum.
    verb wrote: »
    It's no more, and no less, than two center-fed dipoles at right angles to form a more-or-less omnidirectional antenna. No gain.
    Not a bad antenna, but a far cry from a good, high gain, directional antenna.
    Msabot1 wrote: »
    Not in New Hampsha.
    Live Free or Die.
    FestYboy wrote: »
    Yeah, a tuned dipole ain't a bad antenna at all :) I keep a mess of 300 ohm twinlead "in stock" for such projects. In fact, if anyone wants to build one and wants a hank o' twinlead, send me a note. I can certainly spare some.
    https://www.electronics-notes.com/articles/antennas-propagation/dipole-antenna/fm-dipole-antenna.php
    http://hf-antenna.com/003/
    http://www.cyberpoet.net/writes/web/infwiz/spant.html
    to calculate wavelength when you know the frequency, all's you need to know is the speed of light in a vacuum :) which is 300 million meters/second (slightly faster than a Dodge Demon)
    so, in our case, e.g., a station at 89.5 MHz (WVPR-FM in Windsor, VT) has a wavelength of
    (300 x 10^6 meters/sec) / (89.5 x 10^6/sec) = 3.352 meters
    and "lambda/4" (1/4 wavelength) = 0.838 meters = (about) 33 inches.
    Note that one of those references above is for a 5/8 wave dipole (as opposed to a half-wave dipole).
  • verb
    verb Posts: 10,176
  • verb
    verb Posts: 10,176
    Yep. Aren't they directional though? Next thing buy a rotor, down the rabbit hole, you know the drill. :smile:
    verb wrote: »
    A good one is hyperdirectional -- and that's a good thing :)
    I keep a couple of rotators & motors in stock, as a matter of fact.
    Viking64 Posts: 6,688
    Why did ConstantiDIPOLE get the works? That's nobody's business but the TERKS.
