intrconnect 3.1tl
2-tall
2-tall Posts: 98
edited December 2004 in Vintage Speakers
I have a set of 3.1tl's with what i believe is the wrong interconnnect cable.The one that I have has what appears to be a transformer like box in the line.I have been told that this was used with non common ground amps.I am using a carver TFM 24 which is a common ground amp.Should I be using another cable or is this one giving me the best sound.If not can I make a cable out of rc connectors and 16 gauge wire?
Thanks,
2-tall
Post edited by 2-tall on
  • hoosier21
    hoosier21 Posts: 4,408
    I would love to trade you a regular interconnect for the one you have.
    To answer your question, the one you have will work fine.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • trubluluc
    trubluluc Posts: 2,067
    Will work fine.
    And or. you could build your own.
    But if you want to swap, put me in line after Russ.
    I'd like to see if it makes a difference on my amp.
    -Luc
