Good cheap USB cable
afterburnt
Oh and how long is the longest you are supposed to go with USB?
afterburnt wrote: »Oh and how long is the longest you are supposed to go with USB?
Until it becomes obsolete and gets replaced by something else.
*rimshot*
you're good with a 5M decent quality cable2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »you're good with a 5M decent quality cable
What're you using it for, Bruce?
I just grabbed a couple of AudioQuest Forests to use in USB DACs. I like 'em. They got silbur.I disabled signatures. -
@txcoastal1 Ron are you sure, that's a lot of cable.
@msg Scott it's for my laptop to an ifi nano and to try my hand at digitizing some vinyl. -
Nice, Bruce.
5m/16.4ft is the "limit" on USB, iirc, without some kind of boosting/conversion, but I think that's more for non-audio USB. My understanding is that the shorter the better. With a reasonably decent quality shield USB cable, I'd go up to 5m/16 to try. Mine are 0.75m and 2m. I use the shorter one for a headphone amp/dac, and the 2m stays in the home office setup.I disabled signatures. -
Just got a Wireworld Starlight 7 it easily trumps all my other USB cables don't go to cheap on one, unless you need a longer one than 2 meters.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
@gudnoyez Steve this is not going to get a ton of use but I need at least 3 meters. I kinda thought I heard you weren't supposed to go more than 2 meters.
All seriousness, I used a 5M AQ Forest at most of my shows from laptop to DAC when I was running JRiver2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I'm using a Forest with laptop to OPPO not bad at all and a good price. I heard up to 2 meters is best.txcoastal1 wrote: »All seriousness, I used a 5M AQ Forest at most of my shows from laptop to DAC when I was running JRiver
Ron that Forest is too much. Any thoughts on the AQ Pearl? Even that's too much, I only got eight bucks of change out of my ashtray.
This Lucky Goldstar tablet's spell check bites! -
afterburnt wrote: »Ron that Forest is too much. Any thoughts on the AC Pearl? Even that's too much, I only got eight bucks of change out of my ashtray.
Then move your chair or buy an Iphone/Ipad show your love to Apple u scrooge2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Apple is not only not right; it is not even wrong! LG is just stoopid.
I am gonna get the bottom of the line Wireworld cable
Monoprice it is!
https://www.monoprice.com/product?p_id=5438afterburnt wrote: »Ron that Forest is too much. Any thoughts on the AQ Pearl? Even that's too much, I only got eight bucks of change out of my ashtray.
Check the other ashtrays.
Look for a used one on US Audiomart. Your coin will go a lot further buying used. Though for the length you need and the budget you have, Monoprice is about your best option.HT SYSTEM-
lsi 9's -
I have the Pangea cable and it works great, nice and cheap too
@AsSiMiLaTeD i have a Pangea silver that I like but it's too short it was cheap though.
@tonyb Amazon has a WIREWORLD for 42 bucks and I have a store credit so I can afford it. -
Find a Belkin Gold on eBay. Great quality, cheap. I'd stick with 3M or shorter.
Here is one (no affiliation)
https://www.ebay.com/itm/NEW-Belkin-USB-Hi-Speed-Cable-A-B-10ft-3m-Gold-Series-24K-Gold-Plated-Connectors/222873620288?hash=item33e44d8f40:g:-bcAAOSw-WFaoXcoFor rig details, see my profile. Nothing here anymore... -
https://www.ebay.com/itm/NEW-Belkin-USB-Hi-Speed-Cable-A-B-10ft-3m-Gold-Series-24K-Gold-Plated-Connectors/222873620288?hash=item33e44d8f40:g:-bcAAOSw-WFaoXcoFind a Belkin Gold on eBay. Great quality, cheap. I'd stick with 3M or shorter.
I made an offer of $7 and it was accepted. you can get the 6 ft cheaper.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
@marvda1 same here. Thanks folks!
@marvda1 how will you use it?
laptop to dacAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
