Low volume with LSi15, LSiC and Sony DA3000ES amp
bbeacham
A month ago I decided to splurge and upgrade my home theater. I bought a Sony STR-DA3000ES digital amp (150w/ch @ 8 ohms, 135W/ch @ 4ohms), 2 LSi15, 1 LSiC, 2 LSi7, and a PSW 404 sub-woofer.
The problem is that the receiver appears under-powered. It needs to be turned nearly all the way up before it starts getting loud, but at this level there is tremendous hiss.
At a Sony users forum, http://www.agoraquest.com/viewtopic.php?topic=9628&forum=51
others are also complaining about this issue, but they have differant speakers.
So far there isn't a consensus as to whether this is a Sony amp problem or a speaker problem. Some people are saying that digital amps will not work very well with 4 ohm speakers (LSi series)
I have a replacement DA3000ES on-order to see if it has the same problem (Crutchfield has been very kind to send me a replacement before I send my amp back).
Does anyone have any idea or opinion as to what might be the issue?
Thanks.
bud
Thanks.
bud
Post edited by bbeacham on
The hiss is definetly from the AVR. I am also a member over at Agoraquest, and have read all kinds of bad comments and information on the new ES series. I wouldn't bother with the replacement, and pick another manufacturer. The problems are very widespread on that new series, and I wouldn't trust it at all.
I never recommend the new ES series, and I am a Sony fan 100%.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Sony STR-DA3000ES
Lsi15
Lsi9
LsiFX
Lsic
Almost the same system asyours, no problems here sounds great.
I am also a Sony fan Even had a Betamax
The only problem I ever had with a Sony product is a 5+ year old DVD 5 disc player that had a software bug. Sony would have fixed it for free, but I was to lazy to ship it. It still mostly works. The bug was in a bell and whistle, It plays discs perfectly.
I hope it was just that Amp, and the new one works.
I own the following Sony products;
DVCAM
DAT
Cassete Walkman
The ES
Two DVD/SACD players
One dvd-rw deck
One vhs player
a sony tripod
I am a brand loyalist I guess .-
You never blow your trip forever! < Daevid Allen -
Something is wrong with these figures, "(150w/ch @ 8 ohms, 135W/ch @ 4ohms)" The wpc at 4 ohms should be higher than the 8 ohm rating.Political Correctness'.........defined
President of Club Polk -
"Something is wrong with these figures, "(150w/ch @ 8 ohms, 135W/ch @ 4ohms)" The wpc at 4 ohms should be higher than the 8 ohm rating."
That is what the manual says. I also thought that the power would be greater with 4 ohms but individuals on the Sony forum are stating this is correct. For some reason digital amps produce less power with loads less than 8 ohms.
Perhaps an engineer can give a detailed explanation.
bud -
Then Sony designed this receiver with a small size power supply. Power rail must be lower at 4 ohm load. That is ****, return it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Hmmmm....if those specs are true then I agree with DJ, return the POS!Political Correctness'.........defined
My Sony Alarm clock puts out 200 watts into 8 ohms, at 4 ohms it loses time and goes into protection mode.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good Lord,
200 watts first thing in the morning :eek:
That's is one killer Alarm Clock.Originally posted by Vr3MxStyler2k3
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Pixie - I am real glad that you were blessed with a good piece of gear. The hiss problem is very widespread, and that is a real disappointment for Sony fans.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yes i began reading the other forums when I read this thread, and the problem is wide spread. I would be upset too.
Why I got lucky I do not know, but I count my blessings and am happy with my purchase. (as happy as anyone can be in this hobby when you can always go better!:) )
This is a follow up on my original post regarding the low volume level with the LSi speakers and the Sony STR-DA3000ES amp.
Crutchfield sent me a replacement amp and the new system works fine. It appears that Sony made a batch of bad receivers since there are many people with this problem. -
That's good to know since things seem to be migrating towards digital amplifiers.
Very good to hear that you are fixed and running clean again.
Sony has claimed un-officially that there was a problem, finally...mostly in response to responsible forum members around the globeCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
sony line
Originally posted by tony27
that will teach consumers out there to stay away from sony receivers. even the es line is JUNK!
Watch it, rookie. We've got quite a few ES users on the forum that take offense to that kind of "broad brush" statement -
Really!?! I've owned ES gear that has put alot of other gear to shame.Political Correctness'.........defined
Hear hear, Jesse! statement like the above ought to be ignored...I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Blah blah, nothing like a Sony basher to keep us on our toes every couple months. We will most likely never hear from him again, or any data supporting the comment. Atypical.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Once I received my replacement STR-DA3000ES from Sony I have been very happy with it. Even the bad amp sounded great at low volume. Coupled with the LSi speakers I am just amazed at how good the new 3000ES sounds.
My only other Sony product at this time is a DVD player (550) I purchased in May 99. It still works great. -
I too was bummed when I bought an ES receiver. Sony seems to be a bit off when they publish their numbers for power. Don't fret though....they will make a good pre/amp. Just hook up some separate amps........I use the DA3-ES as a pre-amp and hooked up two Para HCA-1500's with a Marantz MA-500. After some wrestling with a ground loop problem, I couldn't be happier with the ES performance.
Polk audio PSW 404 does not power up
jbaranyar@yahoo wrote: »Polk audio PSW 404 does not power up
Might want to post this in the subwoofer area...
There is a fuse directly below the IEC plug on the plate amp, check that first.
