Will a Sony str 1060 have enough power
I have 4 Polk ati a7 and 2polk ati a9s and a center center speaker will it have enough power to perform well
Best Answers
Answers
  • But being new it this it I now have another can I piggy back an amp of some sort ?
    And do you have any recommendations
  • tonybtonyb Posts: 29,032
    Short answer is no.
    Your receiver doesn't have preouts to add an amplifier, which the A9's would need. So now your talking a new receiver + the cost of an additional amplifier.
    If you dropped down to the A7's in all 4 speakers, your still taxing that receiver. Keep the A7's up front and maybe grab some A3's for surround duty. Least until the wallet dictates a bigger jump.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • rooftop59rooftop59 Posts: 4,190
    If you want to keep the speakers you have three choices:
    1. Upgrade to a strong receiver with pre-outs and get a 2 channel amp with 200 wpc minimum (5 channel amp would be better). With enough power you could run everything full range and get away without a sub...
    2. Use what you have but get a sub and cross everything over at 80 hz (this is a waste of your speakers but will prevent damage)
    3. Use what you have full range and keep the volume really moderate. This will sound pretty anemic, but if you crank up the volume you will fry tweeters or the receiver.
    Good luck!
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
  • I totally for got to mention AI have Polk sub psw108
    I know this may sound silly but my plan was to use this as a surround sound as well as for rocking the house are there any 7.1 units that will meet these speakers requirements
    I haven’t found any but I’m not sure what I’m looking for at this point
    Or do I need to drop a pair of a7 s out and go 5.1
  • Ok I’ll buy a big bag amp
    Recommendations?
  • I’d like to stay around 2,000 but if I need to go higher I will
Howdy, Stranger!
