Polk Vanishing 700-LS Placement??
Toolfan66
Toolfan66 Posts: 16,894
I just received a pair of these, installing them will be no problem but they don’t tell you which way to place them, or does it even matter, but to me it looks like they should be placed a certain way to the listening/sitting area.
I can’t place them directly above the sitting area because of the duct vents in the ceiling above the sitting area, so they will be about three feet in front, or the rear, haven’t decided yet what might be best..
Anyone have any insight??
  • dolbyd
    dolbyd Posts: 430
    I have those in the MB setup. Great speaker. They blend well with my Lsi7s.
    I would probably go behind you and install them with the tweeters toward you listening position. Going 3' forward would feel more like an Atmos setup I think.
    You will love the magnetic grill on them.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • Thorton
    Thorton Posts: 1,324
    what are you trying to do.....Atmos? Go to the Dolby site.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    Yes they are for Atmos... I should have stated that...
  • dolbyd
    dolbyd Posts: 430
    Ok then I would go in front of you.
    If your only doing 1 pair see if your receiver will let you do a Middle height channel. It would be more in line will Atmos specs.
    If not I would think that the back Height channel setting can work too. The the room correction will account for the distance to your seating position.
  • dolbyd
    dolbyd Posts: 430
    @Toolfan66
    How did the install go?
