XLR for P5 and A23
rburgess714
I have the P5/A23 combo integrated into my HT. Will XLRs give me a gain in performance? I’m currently using Douglas Connection Bravo ICs which made a significant improvement over some old monster ICs?
Regardless I need another set of ICs and could repurpose the Bravos. So should I consider XLRs and if so what should I look for in 200 or less range. Or should I get more Bravos?
Thanks,
RB
Thanks,
RB
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
Office
A lot of the supposed gains, or lack there of, are widely disputed. I had the P5 and A21 for a bit and did use the balanced connection, and, the one thing for certain is thee wa an increase in gain with XLR.
Any recommendations for xlr cables in the 200 or less range?Living Room
Office
Douglas Connection ICs and Cables -
SDA SRS 2.3TL's
SDA 2B TL's -
If your happy with the cables from Doug, why change ? Have him make ya a set and be done.HT SYSTEM-
lsi 9's -
For sure if I am staying with RCAs. I just did not know if XLR made a big difference and they are a bit more expensive so I was going to shop on the used market.Living Room
Office
Okay I I goofed, they really are not that much more. I will be ordering a pair from Doug.
Living Room
Office
I really like Signal Cables XLR's, and recently bought a set ($59) for my Preamp to amp connections.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
FWIW, those $59 (2ft/pr) of XLR's replaced a $329 Kimber Hero WBT's RCA set and sound every bit as good, if not better than the Hero.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Thank you sir. I ordered a pair from Doug yesterday so I am set for now.Living Room
Office
