Do I need a sub with these Usher MD2's?
afterburnt
What kind of music do you listen to?
Yes."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
You name it, I listen to everything that's not new like techno, screamo etc. -
@EndersShadow these things go pretty low, how would it be beneficial to add a sub?
Sent you a test mix
afterburnt wrote: »
That was as clear as mud. I do not listen to new stuff like techno and screamo. I would like to be in a screamo band though. -
Sent you a test mix
@Clipdat thanks, I will have to figure out how to play that as I am disconnected from my PC and other portable devices except my Gorgo pad, but that's only a controller. I wouldn't know how or have any desire to steam music from it. After all it is evil. -
It might be techno though. lolafterburnt wrote: »@Clipdat thanks, I will have to figure out how to play that as I am disconnected from my PC and other portable devices except my Gorgo pad, but that's only a controller. I wouldn't know how or have any desire to steam music from it. After all it is evil.
Yes you need a sub. I love my JL in my 2 channel system. Once you have a sub, you will never go back!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Specifications:
Dancer Mini-Two diamond
2-way system : Diamond DMD dome tweeter 1.25″ ,
mid-low woofer 7″x2 (8948A),
sensitivity: 90 dB @ 1 watt / 1m
nominal impedance: 4 ohms
frequency response (-3 dB): 28 Hz ~ 40 kHz
power handling: 100 watts
crossover frequencies: 2.7 kHz
I am running them with Dayens mono blocks, if you think I would benefit from running a sub it would have to be an itty bitty one. -
An SVS SB2000 would do the trick nicely.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
How many hours on them so far?
The Ushers? Damn near 24/7 365
My company pays my light bill in CA
Everything is rub in unless it needs 500 hours -
afterburnt wrote: »Thinking about a PB16 Ultratxcoastal1 wrote: »Get you a pair of Rhythmic F12SE'sI think if you haven't yet, room treatments should come before a subwoofer . . .
Just this week I ordered room treatments and a Rythmik F15HP. I'll let you know how things turn out with my MD2s. I know I definitely need the treatments.Integrated Amp: Marantz PM-10
Speakers: Usher MD2
Subwoofer: Rythmik F15HP
DAC: North Star Design Supremo
Streaming Source: AURALiC Aries Mini
SACD Player: Marantz SA8004
Power Source: PS Audio PP3 on dedicated 20amp circuit -
Rythmik F15HP added with MD2s last week. I'm using high level inputs as recommended by some here, so I called Wireworld and had them make one cable for me to match the speaker cables I have. Works perfectly.
@afterburnt I'm glad I put this in my system. YMMV but for me adding a sub with the MD2s now gives me the overall sound I was looking for.
Speakers: Usher MD2
@Derf Wow I would love to hear your system, good stuff there. Why did you choose that particular sub?
afterburnt wrote: »@Derf Wow I would love to hear your system, good stuff there. Why did you choose that particular sub?Integrated Amp: Marantz PM-10
Speakers: Usher MD2
@Derf, thanks man! I will have to fire up the printing press and ink up the rollers.
@Derf PM sent
I ain't got no money that I can depend on. Anyone think an SVS SB1000 will do the job when I cash in my bottles and cans?
Are you asking people to think on this site?
Shame on you. -
How bout two, or should I be looking for a big bad better ONE?
I would take 2 lesser rythmics over the one svs sb16.2 channel:
Theater:
txcoastal1 wrote: »
Speakers: Usher MD2
txcoastal1 wrote: »
HEY! Where did he write that? I don't think I can get half a pair! -
I am going to try to try an SVS SB1000. Can I just use some "decent" cables since they wont be carrying a lot of current?
afterburnt wrote: »I am going to try to try an SVS SB1000. Can I just use some "decent" cables since they wont be carrying a lot of current?
Check out the Outlet section on the SVS website. Might save a few bucks.Integrated Amp: Marantz PM-10
Speakers: Usher MD2
@Derf, I am not ready to buy it just yet but I see some cables on sale that I can get now. I am figuring that the cables can be a lower grade since they don't carry much current. I could be wrong??? -
afterburnt wrote: »I am figuring that the cables can be a lower grade since they don't carry much current. I could be wrong???
Speakers: Usher MD2
