Another speaker stand build
westmassguy wrote: »
mdaudioguy wrote: »westmassguy wrote: »
Nope, that's basically it.
It's about the transfer of energy.
It's also why you add mass. You want your stand to be like setting the speaker on the ground. It doesn't have enough energy to vibrate the earth. But it might for a stand (hence the reason I used black pipe for mine). So you make the stand heavy/dead enough that the speaker behaves like it's sitting on the ground.
Two ways you do that.
One, mass. Make it big and heavy so that the speaker is incapable of vibrating it.
Two, density. If you can't make it big and heavy, make it dense by adding damping material like sand or shot or even concrete. That will make things pack real tight in the voids and that makes all the dissimilar materials act like one big damping apparatus. It will tame the vibrations and kill any resonances because the different materials have different resonance points. Those points overlap and they cancel each other out...well more like damp each other. It's the whole idea behind Polk's Dynamic Balance tech.
Anyway, by decoupling the speaker from the stand, you further reduce the transferred energy. Transferred energy is wasted energy and it can detract from the performance of the speaker. If the speaker moves around when playing then there is energy going into moving the speaker instead of playing sound. If the speaker is on a stand, it might not be moving around but it might be moving that stand and wasting energy moving the stand. So make it so it can't move the stand and further help it out by making it so it can't physically act on the stand because of whatever damping material you put between it and the stand.Expert Moron Extraordinaire
Interesting perspectives by all.Home Theater/2 Channel:
dhsspeakerservice.com/ -
It's not a perspective, it's physics. There's actual science around it.Expert Moron Extraordinaire
Yeah, and he slept at a Holiday Inn Express last nightHT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
I wasn't questioning the science.Home Theater/2 Channel:
Finished! I'm pleased with the results. 30.75" tall, and despite being constructed of wood and vinyl, they weigh in at 28.2 lbs each, thanks to a generous helping of audiophile-grade sand.
Loving the T screws, that's a super clean look.
I see you found the black paint
They look great2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Well. that's just great, now I'm going to have to write a fictional story about "Ed Stands". Thanks for ruining next weekend for me!
Nice stands, very professional looking. -
Stands look good!
I don't think that's black paint, looks similar just not true black.
President of Club Polk -
Very nice job.
Note the perfect hair
Thanks guys! Still plugging away at this room. The ceiling isn't yet finished... but somehow the stands got prioritized ahead of that.
So much blackness.
Very nice!
I too can never throw surplus parts away, as there is always a use for them. Every so often I get vindicated by not having to run to the store to pick up an esoteric fastener or something. Well done sir!
BTW, did you paint the oak, or stain it?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Very nice!
Thank you. Spray paint - gloss for the posts and satin for the wood. I do like how the grain shows through. -
I might have missed it in a previous post, it's been awhile since I read this thread, but what are the two holes for in the top plate of each stand? Are the speakers bolted to the top plates, similar to a "Foundation Mount"? Also, is the wall the same color as your shirt?
The speakers have 8mm threaded mounting holes, and I wanted to use them, since the speakers are somewhat in the open. You know, just in case. As discussed earlier in this thread, I still wanted the speakers to remain decoupled from the stands as much as possible. Some neoprene washers and o-rings did the trick. The walls are probably in the same spectrum as my shirt, but this pillow is a closer match.
mdaudioguy wrote: »The walls are probably in the same spectrum as my shirt, but this pillow is a closer match.
Beautiful job thanks for sharing
Because I am The Pumpkinking
Nice job man! I might make myself something like this if I ever get some nice bookshelves... great idea.
Once again, good job! -
Great job! can you please explain your paint process. I like to see the grain texture.
Thanks -
Thanks -
They turned out very nice, good work!
mdaudioguy wrote: »satin black!
WHERE!?!WHERE DID YOU GET IT! -
mlistens03 wrote: »mdaudioguy wrote: »satin black!
If I told you, I'd have to... you know. -
Give him Eskimo kisses?
