Amp for rti a9
13»
  • gp4jesusgp4jesus Posts: 1,132
    A robust 2 or 3 channel amp should top your shopping list followed by next either...
    a hefty sub
    'A6 Center speaker
    something from the RTi A series for surrounds.
    Maybe a separate 5 channel to power sides/surrounds assuming 7.1
    Enjoy!
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 975 Pre/Pro
    Samsung BDP, DirecTV Rcvr, Xbox 360, Dennon LDP, Phillips CD chgr
    Canare 14 ga - LCR tweeters inside; CC outside
    BJC 10 ga - LCR mids, inside & out
    8 ga Powerline - LR woofers, inside & out
    LR: tri-amped RTi A7. Woofers, Rotel 98X amp; M & T, P'sound HCA-1000
    CC: Rotel RB985 -> tri-amped CSi A6
    5 Audio Pro Subs: 1 B1.39: 1 Evidence at each corner
    Surrounds: Hafler XL280 -> AR 12 ga -> RTi A3*
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
    *Bi-amped by years end
  • StevemacStevemac Posts: 1
    Very informative info on this site from last year!
    Any current simple solutions(deals) for a 7.1 AVR with pre amp feature, and a proper power amp to feed my very new RtiA9 towers??
    Stevemac
  • txcoastal1txcoastal1 Posts: 9,602
    7.1 AVR's are easy...what's your overall budget for the pair
    City/State local may also help for a quick search for used gear especially the amps...a Polkie may even chime in pending your local.
    Welcome to club Polk Steve
  • tonybtonyb Posts: 29,032
    Stevemac wrote: »
    Stevemac
    All AVR's have a pre-amp section. Ideally you want an AVR with preouts that allows you to add an amplifier. Most here use Yamaha, Pioneer, Marantz receivers.
    AMPS- You want one a bit warmer sounding to offset the brightness of the A9's. Parasound amps work well, B&k, McCormack, Belles, just to name a few. Buy used, save some coin.
    Use good quality cables too.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • mlistens03mlistens03 Posts: 986
    Don't go with a pro amp. Seriously, DONT. I did, and now I’m stuck with it.
    2 channel
    Speakers: Mission 770 Freedoms
    Integrated amp: Technics SU-v75 and matching tuner
    CDP: Technics SL-PC20
    Cables: Monoprice, Monster, Acoustic Research, and a few generic ones
    TT: Technics SL-3200, direct drive
    Cartridge: Shure M97xE
    Pc gaming setup
    Receiver/amp: Yamaha RX-V665
    Computer: Lenovo g50 (soon to be upgraded to a Dell Precision 690 which is far from stock!!)
    Interconnects: Amazon basics HDMI, Acoustic Research HDMI, Monoprice speaker cables
    Speakers: Boston Acoustics CR75s
    Random equipment on standby:
    Onkyo TX-v940, JBL woofers and tweeters, single Klipsch KG .5, Yamaha guitar amplifier, Peavey Rage 158 guitar amplifier, Kicker comp 12” subwoofer, single Bose 802 series II, a whole bunch of 1”-3” full range drivers, Infinity Crescendo 3007s (on sale), Polk LSi25s
    txcoastal1 wrote: »
    You don't tell her you read the manual, and you tell her you know what the problem is, and you fixed it, because that what men do, fix things
    sure it has a flat response, and sure it has a lot of detail, and yes, it has good and clear lows. But is it enjoyable to listen to? Does it make you grin ear to ear? That’s what really matters.
    Seen somewhere on AudioKarma (I think)
  • rjmaurerrjmaurer Posts: 4
    I've been watching this tread for a while because I'm in the same boat - new A9s and feel they could use a bit more power.
    A bit of background - this is my home theater system which is 7.1 using a Denon 3313ci AVR and in wall/ceiling RT line speakers. The fronts were my old Monitor 10s from the late 80s. I replaced the 10s with RTI A9s and while movies sounded great, 2 channel stereo seems a bit thin.
    So to solve this I've ordered a Parasound A21. It arrives this week. I'll report back what my impressions are going from a 130 watts (stereo mode) AVR vs 250 watts power amp.
13»
Howdy, Stranger!
