Where to go from here?
TheaterBeater
Hello guys..thanks for having me.
I've been putting my system to gather for a while now, and am now looking for a receiver to power it all.
I currently have the following:
RTIA7's for fronts
RTIA5's for rears
RTIA1's for surround
CSI3 center
PSW125 powered sub
All powered by a Pioneer VSX 1027 (165w x 7) via 16g wiring.
I'm pretty sure I'll need to push the speakers harder. Not sure what receiver is a good choice in the 2000$(CAD) market. Any input would be much appreciated. I'm pretty new at designing a proper system, I've always just hooked up the speakers and just placed them where they fit in the room. Over the next year or so I plan on putting a games room in the unfinished basement with a theater-like setup in one half of the room. So placement will be thought out a little better in its new space.
Any suggestions? Can I use the preout to run speakers from a 2nd AVR? Or should I replace my receiver, add an amp? Thanks for your help!!
RTIA7's for fronts
RTIA5's for rears
CSI3 center
PSW125 powered sub
Best Answers
Welcome to Club Polk. Nice system, but underpowered with trying to power 4 tower speakers as well as the others.
You should consider getting a new receiver that has preouts so that you can add a separate amp to power all your speakers to their full potential.
Give us a budget and we will help you spend it!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Yes..i think your right. Underpowered for sure. Just got the a7s and a1s..havent tried to push them yet. I have a couple pre outs on this receiver. If I add an amp for the fronts and center, would that help push the a5s as rears?
I have A9s and a CSIA6 powered by a 3 Channel amp, A3s, and A5s some times swap the A5s with FXIA6, powered by the AVR. I also run dual PSW 111s. Look for a receiver with preouts and get a 3 or 5 channel amp. I think its possible with your 2000 budget if you look on the used market.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
If you got preouts on your receiver and 2000 CAD, that's like what 5000 in American dollars? Look for Parasound, B&K, Adcom. Outlaw Audio has some good prices on new stuff, not sure what you have for an AVR, but put a Amp on the front three and you should be good.Post edited by gudnoyez onHome Theater
Your AVR doesn’t have pre outs, so I would suggest getting another AVR for your preamp. I would look at Yamaha, Pioneer, Older Denon or Marantz if your willing to go used (not sure what their new stuff is like, or if it’s any good), anyone else want to chime in? Whatever you get, make sure it has full 5.1 pre outs.
For separate amplifiers, I don’t know a ton about them, so I will let others help in that area.
Answers
So..if I were to spend 2000$..what would I buy?
Yamaha’s aventage line up is supposed to be pretty good, I would suggest looking at that.
Is it possible to get both for 2 grand? I can't seem to find a decent AVR (with ATMOS) and a power amp in this budget..lol
Hit up A4L for a refurb AVR.TheaterBeater wrote: »Is it possible to get both for 2 grand? I can't seem to find a decent AVR (with ATMOS) and a power amp in this budget..lol
Thanks clipdat..i found the yamaha set yhere. MX-A5100 AND THE CX-A5000...but they will destroy the budget. 11.2 is bigger than I was thinking, but would allow room to grow. They also have a few marantz Act's. I've not had one before..
At the risk of embarrassment..whats the difference between a normal AVR and an Integrated amp? -
AVR stands for Audio/Video receiver, a integrated amplifier usually doesn’t carry video... I think. I might be wrong lol
An integrated is an all in one for audio signals it houses an amp (obviously), source switch for multiple inputs, pre amp, volume control, and sometimes a tuner.
Any other sites like accessories4less?
