Equipment Racks
is there a picture of your setup anywhere ?
post it and you can get suggestions.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Puritan PSM156 -
Not really. It's far too embarrassing to post for public consumption.
Edit: I went through my old threads and I did post a pic at one point. This basically shows the space I'm working with. TV is not there anymore now, and speakers are 703s. *braces for impact*is there a picture of your setup anywhere ?
I wonder what the functional/real world/rigidity/wobble/isolation/etc. difference is between these two:
It would be interesting to see how the spikes are constructed and attached. For spikes to work they need to be well made and firmly attached to something rigid.
Little spikes loosely screwed into a thin endcap on a hollow tube are decorative only. At best.
It looks like the piece that they screw into is separate from the tubes:
Better view of where the spikes are attached:It would be interesting to see how the spikes are constructed and attached. For spikes to work they need to be well made and firmly attached to something rigid.
According to the Solidsteel.it website, it sounds like custom column/shaft lengths are available. So instead of the standard 8" columns, I could get 5.7" columns - thus reducing the overall height of the rack, and hopefully increasing the rigidity by not making the center of gravity so high when the 30lb TT is placed on the top shelf. Interesting.
That design looks OK. Much better than trying to thread spikes directly into a 1/16 inch endcap.
I have a cheapo Sanus rack (pic way back on page 5) and it is similarly designed ( but without any spikes). Screw a bolt into a leg, put a board between them, and screw on the next leg section. Even with a cheap China rack you can feel it firmly bottoming out when you tighten it and it is sturdy when you are done.
Your pic said s series "starter kit". Can you give a link if they just sell the spikes? I am sure the treads on the post are the same as my cheap rack. -
Looks like they sold them on Music Direct at some point, but not anymore:
https://www.musicdirect.com/vibration-control/solidsteel-8mm-spikes-set-of-3Your pic said s series "starter kit". Can you give a link if they just sell the spikes? I am sure the treads on the post are the same as my cheap rack.
Shipping just to me is over 50.00 each. So it's 120.00 a piece. Ouch.
I like it, but, it's not for me.
I'll have to stick with wood I guess.
I’m negotiating shipping for 2 pieces, which will be cut in half for the legs. Yeah he’s pretty steep on shipping. We’ll see what he comes up with.
So the guy came back with a shipping quote for about the same price. No relief.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
I also found these and e-mailed them a few days ago. No response yet. These look much nicer.
http://www.mesgate.com/aluminum-extrusions-80mm-40mm-square-l-shape-with-corner-radius.htmlBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Some of these 'extra stock' extrusions look a lot like Salamander Designs core module designs https://www.salamanderdesigns.com/racks-stands/pro-audio-core-module/ With the right extra stock extrusion product, you might even be able to add these Salamander 'lacing bars' https://www.salamanderdesigns.com/accessories/rack-cartridge-lacing-bars/ I rather like the idea of a continuous pillar as opposed to stacked pieces. Of course there are still the shelves to consider, as well as the feet.
I use a Salamander 36" version of this https://www.salamanderdesigns.com/racks-stands/audio-stands/ for storing my bullpen/testing gear. I got mine used off CL."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Yep. Not sure I would trust the lacing bars to support the component weight per shelf though.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
A relentless search found these. I'm gonna go for it! Free shipping but the unit price is still a bit high. These are designed for a 30x30mm rail interface. I chose to go with a 40x40mm, so I'll have to do a bit of machining to get em to fit up.
Edited to add 1000mm length!
https://www.ebay.com/itm/3060DR-30x60mm-T-Slot-Aluminum-Extrusion-30-series-Length-100-200-300-400-500mm/132314685509?ssPageName=STRK:MEBIDX:IT&var=431639904980&_trksid=p2055119.m1438.l2649
VTI next to Mapleshade
Very nice!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Got a mockup/drawing of what you're going to be using these for?A relentless search found these. I'm gonna go for it! Free shipping but the unit price is still a bit high. These are designed for a 30x30mm rail interface. I chose to go with a 40x40mm, so I'll have to do a bit of machining to get em to fit up.
Had a VTI as well. Was a great rack for the under 300 I payed for it. Knocked off the caps with a brass punch and mallet, filled with sand, red loctite on top and bottom caps. Dynamat crossbars to prevent ringing, dynamat on bottom of shelves, replaced foam thingy under shelves with rubber bumpers. Boom! Hi end Rack!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Yep working on it. In my head right now but will post soon. Got a parts list too.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Here is my inspiration. From Adona. Instead of the octoganal legs I'm gonna use the 30x60mm 1/4 rounds shown above. And the shelf crossmembers will be a bit beefier (40mm square).
Fantastic!
YOU CAN DO IT!!!!
If you go that route, start a new thread ...should be interesting2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Browsing Audiogon... (Thanks @DSkip)
DADDY LIKEY:
https://www.audiogon.com/listings/lis8f7bj-sgr-audio-signature-hi-fi-rack-victorian-ash-veneer-stands#&gid=1&pid=1
750$ per level.....2 channel:
Theater:
Hard to tell from the pics but the cross members seem thin. Some kinda steel, but plate stock. A c-channel or box section would be better for sag. Harder to machine for a DIYer. The Adona racks use a similar design, but welded box section for the cross members.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Nice looking Quadraspire on eBay: https://www.ebay.com/itm/Quadraspire-SVT-5-Shelf-Rack-Black-Bamboo-w-Black-Hardware/112827056091
Tempting.
Edit: I don't know why the auction title and description says that the shelf material bamboo. I asked the seller about that, because they clearly look like the standard wood shelves with a black veneer.
Edit2: The seller is going to take more photos of the shelves and the original box for me. This is a pretty slamming deal considering new this would go for "$2,245". -
I'll build you one just like it for 50% off...I promise2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Hey, it's local! "Item location: San Francisco, California, United States"
It's an art piece! I did read that a "hanging rack" is supposed to be good.32,000.00
Good for earthquakes out there!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Guaranteed that your CD won't skip during an earthquake?Good for earthquakes out there!
