Wooden end caps on SDA-1Cs
Hey Guys I need some help on my SDA's The wooden end caps are basically trash and i need help or if i can pay somebody to do it for me..... like my Monitor 7s these need some help but there alot better than the speakers they have replaced. I would like to go with a complete wood look instead of the speaker grill fabric on the sides then wooden end caps if there's anybody out there that can help please let me know
  • verb
    verb Posts: 10,176
    Welcome to CP! I'm in the middle of doing the same. :smile:
    http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path/p1
  • Oldreliable7m
    Thanks verb those a some really nice sda1s you have i wish mine where the same my wooden end caps are completely rotted i got three blow drivers two midbass driver in the right channel and one blown tweeter in the left but im willing to do what ever it takes to make them look amazing again
  • verb
    verb Posts: 10,176
    You came to the right place! Lot's of Polkies here will help you on your journey! :smile:
    Now if I can just get off my arse and finish em! Oh yeah I have another pair minty 1C's that keeps distracting me! :smile:
  • Oldreliable7m
    :smiley: Thanks i Truly love the sound of these sda's im hoping once i upgrade to the rd0-194 tweeter my monitor 7s will be the perfect partner to these sda's
    F1nut Posts: 49,805
    Every SDA that someone has replaced the cloth sides with wood looks like crap. It simply doesn't work. What does work is to get rid of the end caps and veneer the entire cabinet, which more or less turns them into a Studio version. One guy did his 3.1TL's in cherry, looked fantastic. If that's your plan, go for it. However, you can't use the original grill, so if you want grills new ones will have to be made.
  • verb
    verb Posts: 10,176
    Aesthetics by definition are subjective. It all depends on the quality of execution. There are many examples here on CP and elsewhere of wood sided replacements that look great!
    F1nut Posts: 49,805
    edited March 2018
    verb wrote: »
    They look like CRAP, every single one of them. The reason being are the disjointed wood surfaces. There's nothing harmonious about it.
  • verb
    verb Posts: 10,176
    verb wrote: »
    You're repeating yourself! :smiley:
    F1nut Posts: 49,805
    Yep and on this matter I'll continue to do so.
  • verb
    verb Posts: 10,176
    I'm looking forward to your appraisal on my Zebrawood Side panels! :smile:
  • Oldreliable7m
    Thanks for your comment F1nut i guess i wont go all wood then.... if im making the grills might as well make new cloth sides i'm thinking dark cherry tops like almost a dark blood red or even a dark walnut. also how do i accomplish getting rid of that dry glue on the black vinyl without damaging the vinyl
    F1nut Posts: 49,805
    As far as I know there is no way to completely remove the original adhesive without some damage to the vinyl. Thing is though, you don't have to remove all of it. Just scrape and/or chisel off the excess.
  • FestYboy
    FestYboy Posts: 3,861
    Look up a product called Rapid Remover, we use it for wrapping and it works really well. Not cheap, but a little goes a long way.
    txcoastal1 Posts: 13,132
    FestYboy wrote: »
    Look up a product called Rapid RemovHer, we use it for wrapping and it works really well. Not cheap, but a little goes a long way.
    Good to know next time my wife complains about my music...TFS
  • Oldreliable7m
    Thank you All for your help I’m really looking forward with these two projects I got going if I need any help I will let the awesome Polk forum members know I’ll also will keep you guys posted
  • 250GTLusso
    250GTLusso Posts: 163
    FestYboy wrote: »
    I have read that Rapid Remover is an adhesive remover, specifically for removing vinyl wrapping adhesives on cars and trucks, and it works without causing damage to most painted or bare metal surfaces.
    But will it damage the vinyl on the speaker?
    HT
    Adcom GFP-565 Pre-amp, Adcom GFA-565 Mono Block Amps (Front), Adcom GFA-585 Amp (Side), Adcom GFA-555 Amp (Rear), Adcom ACE-515, Pioneer CLD-3070 Laserdisc, Sony CDP-605esD, Sony BluRay BDP BX59, Samsung 50" Plasma, Polk Audio SDA SRS 1.2TL Front (Walnut), Polk Audio SDA SRS Side (Walnut), Polk Audio SDA SRS Rear (Walnut).
    2 Channel (Living Room)
    Adcom GFP-565 Pre-amp (w/Big Sky Audio Upgrades), Adcom GFA-565 Mono Block Amps (w/Big Sky Audio Upgrades), Adcom ACE-515, Sony CDP-705esD, Magnum Dynalab FT-101A Etude, Polk Audio SDA SRS 2.3TL (Walnut), Polk Audio SDA SRS 2 (Walnut), STAX SR34 Electret Earspeaker System.
    2 Channel (Office)
    Adcom GFP-555 Pre-amp, Adcom GFA-555 Amp, Sony CDP-605esD, Adcom GFT-555 Tuner, Polk Audio SDA 1C (Walnut).
    2 Channel (Garage)
    Hafler DH-110 Pre-amp, Hafler DH-220 Amp, Sony CDP-505esD, Hafler DH-330 Tuner, Polk Audio SDA 2B (Walnut).
  • FestYboy
    It will not. But then again that's graphic vinyl, as opposed to the architectural vinyl that's on the cabinet. At most, I suspect it may soften it a bit, but that's easily cleaned up. Discretionary application is advised after the bulk is flaked off.
    We are dealing with 30 year old material.
  • 250GTLusso
    @FestYboy , thanks for that feedback!
    HT
    2 Channel (Office)
    2 Channel (Garage)
