"OTG" cable upgrade
So is it USB A to A? Yea, sorry if that's the case then I don't believe there are any upgrade options unless you can make your own...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Ok, I looked at the pic you provided again (phone won't let me blow it up). Let's try this again.
I believe what you're looking for is a WTFIT cable.
The adapter you have posted is a female A to B adapter. But from everything I've read so far, it sounds like you need a usb extension cable.
The plug on the ifi supplied cable looks like the big end of this, ignore the micro usb end.
Looks like that extension would work. Fat chance they make an upgraded ectension though. -
You could always make your own... I make custom length charge cables for my phone.
The extension pictured above came from The Dollar Tree... -
I'm not aware of any audiophile/audio specific grade USB extension cables.
Audioquest Dragon Tail might work if your devices are in close enough proximity:
I have an audioquest dragonfly and looked at the dragontail cable, but I can't tell if its actually supposed to be a match for any other their upgraded USB cables. Based on price, I am guessing that it is not, so I just went with a generic alternative.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
It's labeled with the "Carbon" designation, and seems to have some of the same audiophile features as their other cables:
Solid 5% Silver Conductors
Solid conductors eliminate strand-interaction distortion and reduce jitter. Solid silver-plated conductors are excellent for very high-frequency applications, like HDMI audio and video. These signals, being such a high frequency, travel almost exclusively on the surface of the conductor. As the surface is made of high-purity silver, the performance is very close to that of a solid silver cable, but priced much closer to solid copper cable. This is an incredibly cost effective way of manufacturing very high-quality HDMI cables.
Multi-Layer Carbon-Based Noise- and Crosstalk-Dissipation System
This cable's negative conductors are covered with partially conductive Carbon-Loaded Polyethylene. This remarkable material reduces radio-frequency garbage being fed back into the amplifier. The sonic benefit is exactly the same reduction in "hash" and improved dimensionality that comes whenever RF interference is reduced in an audio circuit. In addition, a carbon layer damps interaction between positive and negative conductors, and an external Carbon-Based NDS System reduces external interference.
Hard-Cell Foam Insulation
Hard-Cell Foam (HCF) Insulation ensures critical signal-pair geometry. Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy. Some of this energy is stored and then released as distortion. Hard-Cell Foam Insulation is similar to the Foamed-PE used in our more affordable Bridges & Falls cables, and is nitrogen-injected to create air pockets. Because nitrogen (like air) does not absorb energy and therefore does not release any energy from or into the conductor, distortion is reduced. In addition, the stiffness of the material allows the cable's conductors to maintain a stable relationship along the cable's full length, producing a stable impedance character and further minimizing distortion.I have an audioquest dragonfly and looked at the dragontail cable, but I can't tell if its actually supposed to be a match for any other their upgraded USB cables. Based on price, I am guessing that it is not, so I just went with a generic alternative.
Looks like that could work but it is probably too short. -
You may also have to shave the outer sheath of the female end too.
Couldn't you have worded that to sound less sexual?You may also have to shave the outer sheath of the female end too.
OK...I have to ask because it has been bothering me...why do you reply to quotes ABOVE the quote instead of under the quote? It is just creepy really."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
You must've missed the conversation that Jesse and I had about this here: http://forum.polkaudio.com/discussion/181249/my-awful-experience-with-polk-customer-serviceOK...I have to ask because it has been bothering me...why do you reply to quotes ABOVE the quote instead of under the quote? It is just creepy really.
No. -
At this point what difference does it make? -
Good point Bruce. I'll put him on ignore and make it better for everyone. Thanks for the support."Some people find it easier to be conceited rather than correct."
Does anyone know what's on the other end of this thing?
afterburnt wrote: »Does anyone know what's on the other end of this thing?
https://youtu.be/ou6JNQwPWE0 -
NINTENDO SEIZURE NINTENDO SEIZURE AARRRRRGGGGGHHHHH!!!!!!
It takes extra steps to do that as the natural format puts the quote first above anything else, which should be a BIG clue to anyone how it's done. Therefore, the only conclusion one can draw is it's done the other way to be annoying.
President of Club Polk -
It depends on the style. Mine is B to B.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Hey Bruce!
I forgot about that weird connection on the DAC/headphone amp. for the life of me I will never understand why. I have to do some digging but I have some other stuff thet may benefit you.
lost in March Madness right now.
Congrats to Loyola Chicago even though they Kick K-State rear!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks Darryl and thanks for that boss ifi USB cable!
Hey Bruce!
I watched the 1st 3/4 of the game. ChiLo is playing out of their mind...They must have busted a shite load of brackets
Sorry to derail Bruce
