I need a small sealed sub
Jim Shearer wrote: »F1,
That looks to me exactly like why the guys at DIYaudio told me NOT to use such an amp connected to the speaker level inputs of a plate amp--in bridged mode, both speaker wires are 'hot', and no common ground between channels if both are connected to the plate amp. Those guys at DIYaudio build stuff & I think they know what they are talking about.Post edited by FTGV on -
why are we talking about a bridged amplifier? Who would connect a sub to a bridged amp?!?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Is there a way I can determine if that applies to the Ampino?
I'll defer to Fred, he's smarter than I am.Political Correctness'.........defined
President of Club Polk -
I'm still confused2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
The way REL connects their subs is EXACTLY the same as what is called high level or speaker level inputs. You tap off the same binding posts on your amp and connect to the high level binding posts on the sub. It is entirely safe and is the preferred method as the sub is getting the EXACT same signal as the speakers. Using pre out or sub out connections result in not quite the same signal as your speakers are getting from the amp. That is why the high level method sounds better.
This is exactly the way i run my rear cerwin vega CVT 200 sub in my home theater off my receiver. I run the front cerwin vega CVT 300 sub off the LFE of the receiver. Rear speakers set to large, front and center set to small. For a whlie i ran both front and rear off the high level inputs on the sub amps straight off the speaker outputs to speaker inputs on subs. Only the plate amp crossover was used. Basically nothing more than a well dialed in sub sat combo.
Works great. -
RBH.
Got mine for 50.00 from local Craig's List. Sounds awesome!
Kind of rare but they're out there.
http://www.usaudiomart.com/details/649038883-rbh_ms_81_subwoofer_200_watt/
Most people just listen to music and watch movies. I EXPERIENCE them. -
Velodyne DLS 3500R, a powered 8" with remote control. You can dial in the exact response you need to compliment your speakers.
Invention is the mother of necessity.
"The Vintage Square":
Polk RTA 8T (1988, new to me 2018), Peerless+MB Quart DIY (1992), Velodyne DLS 3500R (2005)
Dynaudio DIY tower 1994: Dual 28 mm soft dome tweeters, dual 9" woofers, custom equal-compromise 2nd order CO, 1.35 cu ft enclosure
Denon DP45-F (1981), JVC QL Y5F (1980), ADC XLM MKIII (1982), Shure V15V (1982)
Sherwood S9600-CP (1981)
Aiwa ADF 780 Cassette (1988)
Custom DIY dual monoblock 235 w/ch IGBT output power amplifiers -
Skip hooked me up with someone who was selling a used REL T 5 and I love it. While I haven’t had enough time to experiment with placement, I would buy a second if the price was right and just go with one behind each speaker in the corners.
ML Dynamo. Best sealed sub you can get for the money...All day every day and twice on sunday.
And TWICE on Sunday? LOL!
Actually, I agree. Good suggestion for a sealed budget sub.edubb46 -
RBH The best small sub I've ever heard.
8" woofer...8" passive on the bottom.
Talk about tight and musical! They are AMAZING! And nice looking too.
I haven't heard a REL yet so...
And if you can find one (good luck) a micropro is awesome!
I've got a 2000DSP model and I'm SHOCKED at how good it sounds. And its super small too boot."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Consider...
https://m.ebay.com/itm/Audio-Pro-Ace-Bass-Sub-Evidence-MkII-Subwoofers/332598568309?hash=item4d706b6575:g:gYEAAOSw5UZY~~1L
Small: 12.5 X 12.5 X 12.5... but not sealedSamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Kinda surprised no one mentioned MK as an option yet...
If you can find them on the used market, I would suggest the Energy ESW-M6 or M8. They are a very small footprint for a sub in the situation you mentioned. I have one for our TV in the family room. It hides well and does an adequate job for it's size (8" cube).
ESW-M6 Specifications
Speakers
Polk 5jr+
Polk SDA 2B
Polk SDS 3.1TL
Equipment
Yamaha RX-V3800 Receiver
Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
