Cambridge Audio DVD 99 Remote
Picked one of these up with no remote. Anyone know where I can get one?
    Clipdat Posts: 12,608
    There's several similar models of remote available on eBay. They might work cross models.
  • DaveHo
    DaveHo Posts: 3,481
    Go Harmony, don't look back.
    audioluvr Posts: 5,438
    DaveHo wrote: »
    Not sure what that is... Dating site???
    Ah. Thanks Dave! I currently have 4 remotes in my TV room. I've been told I can program one remote for everything but have no clue what that entails. Maybe my teenage daughter can do it for me...
  • DaveHo
    DaveHo Posts: 3,481
    edited March 2018
    I love my Harmony remotes & the interface for "programming" them. Very simple to configure, no real programming involved. They have a very large database of supported models. You can check if your particular ones are supported here:
    https://support.myharmony.com/en-us/compatibility
    You do not need the original remote to set-up the Harmony.
    Thanks, got one on order.
