Polk Audio Speakers - "I get no respect!"
    Tony M Posts: 11,015
    Where do I say I demand anything? :o
    mhardy6647 Posts: 33,037
    edited March 2018
    WLDock wrote: »
    Most don't realize the work that went into getting the LSiM line to measure fairly flat yet sound good. Anyone in doubt should read the Tech Brief then go listen to a well setup pair.
    Some critics that took the time to listen and measure them seem to have good things to say....
    "The LSiM703's output is astonishingly flat from the low midrange through to the high treble." - Stereophile
    Sort of back on topic ;) Here's a link to Stereophile's 2012 review of said LSiM703. Readin' it now, I am.
    https://www.stereophile.com/content/polk-lsiiim703-loudspeaker
    * impedance and phase curve:
    (note how low this "compatible with 8 ohm" loudspeaker's impedance dips between 90 and 200 Hz!)
    * "... anechoic response on HF axis at 50", averaged across 30° horizontal window and corrected for microphone response, with complex sum of nearfield responses plotted below 300Hz":
  • Nightfall
    Nightfall Posts: 10,067
    Tony M wrote: »
    Gas and air have no SUBSTANCE therefore can't be a fluid. Period.
    What does the GAS surrounding the earth have to do with liquids?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Viking64 Posts: 6,679
    I always thought that "fluid coupled" was in reference to two people comfortable enough with each other that they are willing to exchange fluids.
  • Joey_V
    Joey_V Posts: 8,519
    tonyb wrote: »
    I think you boys are reading too deep into semantics here. Must everything be an argument ?
    The term "fluid", when mentioned in audiophile terms, relates to the flow of the sound, not whether xyz is a gas, liquid, or some strange alien compound. How the heck did we even get there from discussing Polk speakers ?
    ....and Russ has even chimed in yet. :)
    Tony,
    I think you missed the point. Fluid in the Polk ad campaign meant the air behind the passive radiator was a fluid unit.
    It’s not about the air moved by the radiator aka sound waves.
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    txcoastal1 Posts: 13,132
    edited March 2018
    So why is there fluid in the passive, do they get hot
    Is it a ferrofluid.
    edited March 2018
    Joey_V wrote: »
    tonyb wrote: »
    Tony,
    Yea, I know. Polk promoted it as an internal property.
    I say it's compressed air that moves the radiator. Polk says it was Fluid. They are the same thing if you count the MOVING AIR as the fluid. ;) It seems from what I read, something has to be moving through air or the air is moving something for it to be called FLUID. It's simple science in that way. Air moved the PR, therefore it can be a fluid according to scientists.
    I believe the theory since Leonardo Da Vinci's drawings of FLOW diagrams was genius, it grew into anything that flows was incorporated into Fluid Dynamics years and years later. It made calculating anything, be it liquid or Gas or Air, easier to chart and put down on paper for mathematical calculations when those elements were put in motion. It was a good thing! I LOVE Math!
    I get the College and Scientific Society labeling that John is so learned in the subject.
    But from what I just read from one of John's links, The 200 page coverage of Fluid dynamics does say what he has said. The community put Air and Gases into the Fluid category since it followed waters characteristics in some ways when it was flowing or being acted upon.
    Therefore, friction, compression and a ton of other tests could be calculated in the Air and Gas fields of Science. I don't want to list the men I just read about who contributed their knowlege to get us to where we are today but they were smarter than me in their field of Fluid Dynamics. But could they build a cottage? :p
    He's right in his scientific knowledge of FLUID Dynamics incorporating GASES. I personally see my point and his. He just doesn't want to see my point.
    If you question 1,000,000 people and ask them if air is a fluid, what would be their answer? That's my point. ;)
    I leave the mathematical and materialistic explanations on Fluids for good now.
    Post edited by Tony M on
    nooshinjohn Posts: 25,095
    Leonardo Devinchi :o
    Viking64 wrote: »
    I believe that's referred to as swapping spit.
    If you have any other fluids in mind -- bad pug! bad, bad pug!
    Oh, that's the vanno blanco speaker guy, isn't it?
    swapping spit.
    I was going to use that naughty phrase, but then I decided against it just in case my mother is watching. :p
    she might prefer trans-salivary equilibration.
    Well, she was a teacher. (Which might explain some of my internet exploits.) LOL
  • steveinaz
    steveinaz Posts: 19,522
    edited March 2018
    I tried a few Polk speakers, but I was primarily an Acoustic Research and Infinity guy in the 70's-80's. I tried both SDA and Carver's holographic generator technologies, didn't really care much for either. In their defense, however, I was in the Army and typically had a pretty small listening area--not exactly ideal.
  • verb
    verb Posts: 10,176
    It’s a little known fact that glass is a liquid and NOT a solid. It is also a fluid.
    Sort of correct. It is what we call an amorphous solid.
  • Jstas
    Jstas Posts: 14,712
    edited March 2018
    Tony M wrote: »
    You have no point.
    You are wrong and refuse to accept it even after being given proof of your incorrectness.
    This is proven science, fact, that you are deliberately ignoring for the sake of your "point" of which you have none.
    The point of scientific research is to eliminate the uncertainty. Therefore, despite what the uneducated masses think, the science is real and correct.
    But, according to my grandmother, to illustrate the stupidity of the general public, if stuff like this was left up to them, a fool would have jumped off a bridge already because a million of those people thought it was a good idea.
    Expert Moron Extraordinaire
    This is directed at no one in particular and to everyone (myself included) in general.
  • verb
    verb Posts: 10,176
    Adding to the fray :smile:
    Boiling point of air is about -195 celsius, when liquid air phase changes into a gaseous state.
    Hydraulic Fluid (depending of which type) begins to boil at about +300 celsius.
    This is of course pressure dependent, as that would affect the boiling temps.
  • lightman1
    lightman1 Posts: 10,776
    Look up wind tunnel testing, dingleberries.
    Fluid dynamics at it's most simple form.
    "Air" has fluid properties.......
    I change light bulbs......
    Clipdat Posts: 12,599
    @Jstas I bet you're really fun at parties.
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    So I read through this thread again after having missed much of the banter since work keeps getting in the way!
    Yes I am an engineer by trade, and had to interject some commentary on phase changes between materials. But back on topic, sort of.
    I wonder why that almost every thread that @Clipdat introduces invokes such passion? :wink:
    I too miss the ability to audition items locally. However the boutique shops do emote a bit of superiority at times, but that comes with the territory, IMO. So be prepared.
    When I first got into Cigars the same experience. They really do size you up, if you will, and predetermine what value you have to them, IMO. Am I gonna ask about the latest Montecristo? Or the Grenadiere 5-pack? Again, other shops just the opposite. Those are the ones I frequent.
    I recall walking into a local Harley dealership after work with a Suit on, it was nearly 30 minutes before I was acknowledged! Other Harley shops are different, and I frequent those now. I ride an additional 20 miles to purchase items from that shop driving right past the Harley shop down the street. I think the term they use is Lookie Loo's.
    The internet is great as there are places like this, and other ratings sites where you can do your research. You also have such a wide array of offerings on the internet that the local shops simply can't afford to keep in stock.
    My personal rule is that if I can buy an item locally, I will. But I always use the internet to do my research first.
    Just my thoughts.
    edited March 2018
    I was excited and eager that the first shop I mentioned was actively corresponding with me over email and replying same day. I was looking forward to maybe visiting them and checking out some Rogue Audio preamps.
    I could email them again and push the issue I suppose. I kindof feel like they are doing Rogue a disservice because they basically just gave up on a potential sale.
  • verb
    verb Posts: 10,176
    Exclusivity is part of any boutique brand. It enables them to charge higher prices, bigger margins for them, and they sustain a business model that way. there are many examples out there, from cars, watches, clothing, just about everything.
    Certainly the expectation of quality and performance rises with price, but to a diminishing point. At some point all things being relatively equal, brand image is what makes the sale.
    So they're playing "hard to get" as a business strategy?
  • verb
    verb Posts: 10,176
    Could be, since they know what your rig consists of. Or maybe they're super busy with other highfalutin clientele. :smiley:
    I emailed this shop like 5 months ago as well asking if they carried any linestage tube preamps and they never replied.
    Either I just have really bad luck and people don't like me, or all the HiFi shops around here suck.
    verb wrote: »
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    Softball. Maybe all three! Just kiddin dude! :smiley:
    lightman1 wrote: »
    Did you see my Schlieren optics photo of the XB-70, ol' son? :)
    oh no, he's got me on ignore...
  • verb
    verb Posts: 10,176
    lightman1 wrote: »
    We actually had a supersonic tunnel at my undergrad school. Took about 20-30 minutes to charge the pressure vessel. Hit the button, and BAM, all over in a second! My introduction to Schlieren. :smile:
